Can I use this output transformers with a 5965?
Likely will be a bit light on bass. Inductance needed for -3db at 20 Hz, for the 5965 is 27 Henry, with -0.5 db some 2.76 times that. The other tubes need around 15 Henry for - 3db. If your transformer is from Lundahl, they generally post the useful inductance out in the middle of the permeability range. A 1volt 120Hz test will provide you with the lowest operational inductance of the device, but you need to know the permeability curve of the core material to guess at what will be available. Typical inductance will be about 10 times what the 1volt 120 Hz reading shows, from an inductance bridge.
Bud
Thanks Bud. I am having bass issues.
That all makes sense. I've been searching for a output trans that would work. I've contact Lindahl and Silk. Silk can build a 12K:600 ohm (1 :0.22) OT but he insists on potting it and I've been told potting can create problems.
Not potting will create even more problems, like corona death in under 12k hours of use, as opposed to 300 K hours with vacuum potting. I will not let a high voltage signal or power transformer out of our plant without vacuum potting. Plus, we only build to CE 6500 safety standards. All of this so you don't end up with a fire or shock hazard.
Bud
Hey Poinz,
Long time no see.... I suspect I am missing far more than you are, but, here is the data I have. Doesn't mean I understand it with the same clarity that you, or any amp designer must, but it is the data I would design from, out of Frank's archives.
5965
Plate resistance 7250 ohms
Transconductance 6500 ohms
3427 Z ohms without pri DCR 27.87 Henry for -3 db @ 20 Hz
5687
Plate resistance 3000 ohms
Transconductance 5400 ohms
1928 Z ohms without pri DCR 15.35 Henry for -3 db @ 20 Hz
6SN7
Plate resistance 7750 ohms
Transconductance 2600 ohms
1946 Z ohms without pri DCR 15.50 Henry for -3 db @ 20 Hz
Bud
Hi Poinz,
Back when I was being "forced" to learn how to design outputs for tubes, in 1974 when tubes were dead, I was told to add the Plate resistance, either one I calculated, or one given in mhos and shown as transconductance, in parallel with the load line. This, added to the DCR of the primary and the square of the turns ratio times the secondary DCR, would give me a figure for primary reactance. Dividing that number by two pi and the frequency of interest would give me the primary inductance I needed, out in the power band, to support a - 3db power output at that frequency of interest. Multiplying that number by 2.76 provides a -0.5 db power output.
In SE OPT's there can be resistors in the plate to ground path that occasionally swamp the Rp and then they become the Rp. Please understand that my education was at the hands of practical transformer engineers who wanted something close to an ideal answer, but due to the +/- 25% nature of E/I core permeability, worrying about the last bit of refinement was not acceptable.
I am always willing to learn better methods.
Bud
