3886 is robust chip amp, it has all sorts of protection.
But no protection from wrong wiring.
Post schematics you are following. Post pictures, lots of it, high quality. We may be able to spot something. I have seen people use single supply with no cap on the output...then they wonder why it does not work.
I will soon build two amplifier channels using this chip when my order arrives home. The PCBs have been made quite neatly using the acetone toner transfer method and a solution of hydrogen peroxide plus muriatic acid as etchant. The remaining step is to carefully inspect all the tracks for minute shorts with a magnefying glass. After that, I will check that the PCBs comform with the chip's pinouts. Misplaced schematics in the internet are not an impossibility.
- Chip Amps
- LM 3886 18v at output
