diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   what kind of relay is normally open but will close when triggered? (https://www.diyaudio.com/forums/parts/85036-relay-normally-close-triggered.html)
jarthel 20th August 2006 01:30 PM
would it be dpno? thank you.
mrshow4u 20th August 2006 01:38 PM
Most relays are NO (Normally opened). So you need a double pole? Sometimes they come as DPDT double pole, double throw. If you get DPDT, you can choose to connect to the NC (normally closed) of the NO (normally open) contacts. The other contacts will be the common connection. Here's a typical datasheet <http://pewa.panasonic.com/pcsd/produ...pdf_cat/hc.pdf>
jarthel 21st August 2006 11:31 PM
thanks for the help
AndrewT 22nd August 2006 08:17 AM
do you need double pole or would single pole do?
SPST are usually NO. and due to the single contatc are often rated at higher currents
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
