Hi, I have a loudness circuit which need to reduce "output". how may I achieve this by fixed resistors by around 6-9db? How to calculate values?
View attachment PM6006 Integrated Amplifier Service Manual PG9.pdf
The "Loudness' Circuit is oftentimes what they call the hearing curve compensation. It is a special dynamic type of EQ that adjusts the sound to the human hearing sensitivity when levels are below a certain threshold. Not enabling it should have it disabled. It is not active when it is not enabled.
If I want to remove the "treble lift" in the loudness circuit, should I remove and short C2501 / C2502?
Switch the 'Loudness' off and use the bass eq to boost instead.
I see no need to go inside the thing.
Sorry for my late reply as I was busy with work. The amp now sounds better so far.
I would like to express my thank everyone for their advice on this thread as I have gained much on understanding the circuit.
Last question : What does changing R2501 / R2503 achieve, that is after adding 50 K adjustable resisters after C2503 / C2504.
Best Regards.
Best Regards.
- reduce loudness circult
