The U1 is more of my challenge, U12 is KA317, could U1 be the negative (adj) regulator 337?
Should I check if the output pins is connected to the op amp B+ and B- respectively?
P.s. U1 and U12 is the last component on both side to the RCA end of the board (one is missing).
