diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   GedLee (https://www.diyaudio.com/forums/gedlee/)
-   -   Testing / Verification of Gedlee Abbey Kit? (https://www.diyaudio.com/forums/gedlee/348940-testing-verification-gedlee-abbey-kit.html)
kivitel 31st January 2020 03:58 PM
I'm currently building a pair of Gedlee Abbeys from a kit which was purchased by someone else some time ago. I've assembled the cabinets and I'm about to do the crossovers and final assembly.
I was wondering if anyone had any recommendations for measuring these speakers after completion, just to make sure I haven't done anything egregiously wrong. I have arta and a measurement mic, but it would be helpful if someone could recommend the axis, measurement distance and expected response.
Alternately, I could do an impedance sweep of the final system, but I can't seem to find an impedance graph of this speaker.
I understand Dr. Geddes is retired so I'd like to avoid bothering him directly; curious if any other Abbey builders have done any measurements.
Very much looking forward to hearing these speakers!
Thinkcat 31st March 2020 05:32 PM
Maybe you should (or could) just do it and then see if there is anything really suspicious.
I am slowly proceeding with ordering the crossover parts and the rest of the panels for the enclosures (need to settle on measurements, go to local hardware shop and expect them to do a bad job, then cut the panels to final sizes at home). I'll use baltic birch plywood. After I have assembled mine, I can also do measurements. But knowing my glacial pace with these things, it will take at least a month or two.
EliGuy 13th August 2021 10:52 PM
Quote:
Originally Posted by kivitel (https://www.diyaudio.com/forums/gedlee/348940-testing-verification-gedlee-abbey-kit-post6066150.html#post6066150)
Sorry to revive an old thread but I want to someday do one of the bigger Gedlee kits. Ive owned the Nathan which was impressive in some ways and Earl said they werent very good compared to its bigger brothers. So how'd you make out on the kit. Impressions??
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 16.67%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
Wiki
