Hi!
This topic bothers me lately. I would like to use as small resistors as possible in the feedback, but I do not want to overdo it. As a presumption, do not exceed a certain power or current per resistor and it results from the maximum op-amp output voltage that I have?? How to calculate it? I mean this current/power per resistor for a specific op-amp.
Each opamp has a minimum load impedance it can comfortably drive without increase distortion - usually this is clear from the datasheet graphs where they often show curves for different loadings, the lowest load resistance shown is likely to be the limit for best performance (manufacturers like to show off a chip at its best).
Any random opamp is likely to be able to drive 2k without issue. Some are happy down to 1k or 600 ohms, but not all.
The output swing will be diminished with low impedance loads (even if the distortion doesn't increase). What is touted as a rail-to-rail opamp will not be when loaded to 600 ohms - in fact often to get reasonably-close-to-the-rails output swing you'd limit the output load to 10k minimum impedance.
I can read the question in more ways. Mark did one good interpretation.
One way to read the question is: what is the maximum power loss in the feed-back resistor of an OP-AMP, going from the output of the OP-AMP to the inverting input?
We call the resistor going to ground (non-inverting OP-AMP coupling) or to the input (inverting OP-AMP coupling) R1. We call the feed-back resistor R2. The signal across the feedback resistor is then the amplitude of the input signal multiplied with R2/R1. The power loss in the feedback resistor is then found by the RMS value at the input multiplied with R2/R1, then squaring the result and finally dividing the squared result with the value of the feedback resistor. For the max. power loss in the feedback resistor, use the (RMS value) of the max. input amplitude.
Bob Pease wrote an application note on the topic: http://www.ti.com/lit/an/snoa471b/snoa471b.pdf
Application note 1485
Thanks! I did not read the TI application yet. It looks like a good piece of thing.
@Mark Tillotson
What about power amplifier chips like LM3886. It can be loaded with 4ohms, or lets say 6 amps, but datasheet still recommending R2=20k and R1=1k. Why resistors that big? You can set 23V RMS at the output for the 8ohm load, this is about 25miliwatts at 20k resistor, only 25miliwatts. And 1,6mA at the peak of the current swing.
@Mark Tillotson
@Mark Tillotson
OK, you meant resistance value.
Why would it be an advantage to reduce the feedback voltage resistor divider below what would make a difference for the chip? You would only require larger power rating of the resistors. If you lower the resistor values and use a capacitor in the line to ground (non-inverting OP-AMP coupling) to reduce gain at very low frequencies and DC, the capacitor value will need to be increased for the same cut-off frequency.
I never use this HPF capacitor under R1. I only use the coupling serial capacitor on the input. Lower resistor values mean less noise. The AD797 datasheet boasts low noise thanks to the use of small resistors. They also boast that AD797 works well with small resistors (it has 50mA output current capacity)
https://www.analog.com/media/en/technical-documentation/data-sheets/AD797.pdf
Page 13, Table 6
In power amps, lower feedback resistors help to lower the noise figure, as well as reducing the effect of non linearity in the input impedance of the LTP.
You can take this way too far of course, and in a poorly thought out power stage it is easy to go past the point at which the resistors are no longer a significant contributor to the system noise, but it is surprising how often the feedback network dominates the noise performance of a power stage. Much more of an issue when you have a high power amp that spends 99% of its time 30 to 60dB below peak output of course.
For most audio opamps (excluding the low current stuff like {06/07/08}x and the cmos low supply rail stuff, 1k or so is about as low as I like to go unless I am doing really noise critical things in which case sums are indicated (Remember, Voltage noise is NOT the only noise). In a big power stage going that low can cause an annoying amount of dissipation, so you sometimes need to go higher to avoid needing a 10W resistor in the feedback path (Which is just silly).
You mention the LM3886 yourself. I am convinced that you can replace the 20K with 2K and the 1K with 100 Ohm. The capacitor is no problem, then. I doubt you can really hear a difference in noise.
Your output offset may increase as the DC impedance level difference seen between the two inputs increases.
In the signal, if I have to use a 500R resistor, I do not care, but above 1000R I am already starting to think if it can't be made smaller. As you say, we often listen to integrated or headphone amplifiers below 30 or 40dB from full scale. Then the noise gives its character to the sound, in a word it belongs to audible distortions.
Interesting, I didn't know about the output offset issue.
I trust your experience and the theory behind. I generally use the values recommended in the datasheet because why would the company trying to sell me their chips not tell me how to achieve optimum performance?
As a test, I put my ear to the speaker (without music) and normally I have no hiss I can clearly notice. Then I accept noise as not being an issue.
You have two types of offset generating current from the two input lines: a common current that is transferred into an offset voltage when the inputs see a different DC impedance. The higher the current and the higher the difference in impedance, the more offset voltage. Then you have a differential (difference in) current that evidently creates an offset.
Interesting, I didn't know that. I don't care much about small offsets. Today I had the opportunity to audibly compare and measure the greater and smaller signal-to-noise ratio. I've made such sensitivity switch on the headphone amplifier input (1: 5). The comparison is like 114dB vs 100dB fine noise distance, and 90dB vs 80dB hum, a bit high. It's worth fighting for these SNR decibels. High level sound much cleaner, clearer, bass also deeper and clearer, everything is better, less hazy.
Interesting. Which chip are you using for your headphone amp?
How low a value do you use for the feedback resistor?
@Mark Tillotson
Too small and they will have self-heat leading to value changing slightly with load. 20mW will be definitely warm (but not hot) with standard parts. Somewhat lower values will reduce noise (though the chip itself may be the limiting factor), but the larger value resistor may need to be higher wattage if you chose, for instance 330R and 6k8, and the DC blocking capacitor gets very big.
This is LME49720 and LME49600, normal datasheet application. The resistors are now 2500R and 75R. I had other values before, like 10k/500R, or 2700R/120R giving less gain. I think bigger 34x gain sounds better, smoother - this is other thing, maybe running more stable.
The TCR factor, I was thinking about this. On the other hand, does the resistor temperature change so quickly that we can hear distortion? Is the resistor not having any significant temperature inertia that stabilizes it in time? Do you think 20mW is warm? I don't think so. I've got one 1-watt melf running on 300mW constant now and I can say it is warm, 38C maybe.
Many thanks for the info.
I normally use TPA6120 for headphone amps. For feedback I use 2K2. I hear no noise but it is also close to your feedback resistor value.
I didn't know this TPA. Is this typically intended for volume control on the DAC side? On the digital side?
I see that it requires a series 39R resistor at the output? LME apparently does not require, but I wondered whether or not to give at least 2 ohms - just in case.
- Chip Amps
- How to calculate the min. feedback resistor value in op-amps.
