diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   PC Based (https://www.diyaudio.com/forums/pc-based/)
-   -   Raspberry Pi4 announced (https://www.diyaudio.com/forums/pc-based/339536-raspberry-pi4-announced.html)
soundcheck 24th June 2019 07:34 AM
Great news. RPI 4 is out.
Raspberry Pi Blog - News, Announcements, and Ideas
Several serious (long time requested) improvements have been introduced:
* separated ethernet/USB
* BT 5.0
* USB3.0
* up2 4G RAM
* and more
Enjoy.
Yatsushiro 24th June 2019 08:16 AM
4GB version on it's way to France...
soundcheck 24th June 2019 11:11 AM
As usual, I'll wait 2-3 months to let the dust settle. ;)
They slightly changed the layout. New cases need to become available.
mterbekke 24th June 2019 12:01 PM
Quote:
Originally Posted by soundcheck (https://www.diyaudio.com/forums/pc-based/339536-raspberry-pi4-announced-post5833119.html#post5833119)
https://www.raspberrypi.org/products...rry-pi-4-case/
Need any more dust to settle ;-) ?
Bas Horneman 24th June 2019 12:13 PM
Ordered 2GB version today. Including case.
https://www.raspberrypi.org/products...rry-pi-4-case/ site can't be reached (at the moment)
soundcheck 24th June 2019 12:23 PM
Quote:
Originally Posted by mterbekke (https://www.diyaudio.com/forums/pc-based/339536-raspberry-pi4-announced-post5833151.html#post5833151)
Yep.
Actually "dust" refers to firmware and driver issues. ;)
Usually it takes a while to get the issues under control. Usually even more then 2-3 months.
...then all the audio OSes need to adapt properly.
I'll probably get onboard around September.
CharlieLaub 24th June 2019 12:49 PM
Wow, they kept that under wraps pretty well. Had not heard of an imminent release of the Pi 4, but am definitely excited about it.
The increase in processing power, available RAM (1, 2,and 4 GB options now exist!) splitting of USB and ethernet, etc. will all make this very competitive with other ARM based SBCs and even with some low end (e.g. Kaby Lake, Gemini Lake) Intel based mini-PCs.
Allowing some time for things to shake out and the Debian Buster based OS to become available is not a bad idea, but why wait? Start having fun now!
CharlieLaub 24th June 2019 01:29 PM
I found some benchmarks run on the Pi 4, that compare it to previous Pi versions, here:
Benchmarking the Raspberry Pi 4 - Gareth Halfacree - Medium
randytsuch 24th June 2019 03:08 PM
Quote:
Originally Posted by CharlieLaub (https://www.diyaudio.com/forums/pc-based/339536-raspberry-pi4-announced-post5833213.html#post5833213)
Thanks, interesting article.
The A72 core and separating ethernet and usb (finally) appear to make a big difference in speed.
I expect heatsink companies to start working on thermal solutions, looks like you can't throw on a little heatsink and put in a small case anymore.
Randy
Yatsushiro 24th June 2019 03:10 PM
Quote:
Originally Posted by CharlieLaub (https://www.diyaudio.com/forums/pc-based/339536-raspberry-pi4-announced-post5833190.html#post5833190)
...and the Debian Buster based OS to become available is not a bad idea, but why wait? Start having fun now!
Raspbian Buster is available for download on all RPi's:
Download Raspbian for Raspberry Pi
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
