diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Parts (https://www.diyaudio.com/forums/parts/)
-   -   Ferrite Magnets (https://www.diyaudio.com/forums/parts/337910-ferrite-magnets.html)
Hayden 14th May 2019 02:27 PM
Ferrite Magnets
Hey ya!!
Where’s the best place for ferrite ring magnets? About 10 or 11inch diameter and about 1inch thick.
Cheers
Mark Tillotson 14th May 2019 06:22 PM
Best meaning cheapest? 190mm was the largest size I could easily find, this sounds like a custom magnet you are after.
JMFahey 19th May 2019 05:26 AM
I can easily buy up to 190mm diameter magnets (EV and Altec size for 63 and 75mm VCs) in Argentina, in boxes of 10.
My supplier can get me on demand 220mm and 250mm ones (JBL size for 102mm VCs) , but must order 1000 of them at least and it takes 30 to 90 days to have them delivered, order must be synced with others they already have so they all travel in same container.
My point being that you can probably do the same in Australia and also that I doubt you can get "just a few".
Hayden 22nd May 2019 01:49 PM
Thankyou so much for your reply :)
I know they are hard to get, I was after at least 250mm ring magnet by 1inch thick.
It’s for a speaker build. I was going to go neodymium as you can use smaller blocks BUT they are hard to get too and also expensive!! :eek:
Most manufactures only sell in mass amounts so I thought there must be someone that buys in bulk and sells them individually???
Or maybe buy a speaker motor and pull it apart.....
asifaadish 10th June 2019 09:05 AM
Hey Hayden Check this out.
Hengdian Group DMEGC magnetic limited
chris661 10th June 2019 09:19 AM
If you only need one, you might be able to request one for testing purposes.
Chris
asifaadish 10th June 2019 09:34 AM
Hi
Chirs i they have the size what you are looking for, but for one piece the shipping cost will be extremly high why dont you ask them directly?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright ©1999-2019 diyAudio
Wiki
