diyAudio
diyAudio (https://www.diyaudio.com/forums/index.php)
-   Multi-Way (https://www.diyaudio.com/forums/multi-way/)
-   -   Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way? (https://www.diyaudio.com/forums/multi-way/334757-cover-spectrum-spl-low-distortion-2-a.html)
camplo 3rd March 2019 09:26 PM
I've been on a quest to build my own own reference monitor. In that journey I've come to know the JBL m2. Maybe its highly prized for its flat response but all I see is another 2-way. There are already flat two ways on the market. So not sure what the hype would be around this speaker, beyond having accuracy and spl, making useful for far field as well as near field.
As a full-range solution if a 2 way that took care of sub bass, gets rid of another cross and thats cool. I've found a driver that could be used for the top
FaitalPRO HF146 - 1.4" Compression Driver
A woofer for the bottom can be found. The question is, how is a woofer that is going to be easily responsible from 30hz to ~1000hz going to behave? Lets say we are auditioning rap, edm, or some other deep bass reproduction that causes high woofer excursion, how is the top range of that speaker going to sound? It seems to me a 3 way is almost always better, but I'm not the finally say, the results are, anyone have a strong opinion on this?
jkrokenberger 3rd March 2019 09:36 PM
I have a set of Dynaco A-50's. They are 2-way with a dome tweeter and 2 10" woofers. They are excellent all around, even when driven hard. So, yes it can and has been done. The woofers are low mass/hi-efficiency and garner the low end extension from cone area and enclosure design.
rayma 3rd March 2019 10:33 PM
Quote:
Originally Posted by jkrokenberger (https://www.diyaudio.com/forums/multi-way/334757-cover-spectrum-spl-low-distortion-2-a-post5717273.html#post5717273)
The Dyna speakers are really good, but they do roll off in the top octave.
Angling them inward can help with this.
tommus 3rd March 2019 11:34 PM
what is "high SPL" for your application? (at 30hz especially)
camplo 4th March 2019 12:44 AM
~110db? maybe 114db? from 1 meter away. I can't find a frequency chart on the Dynaco A-50's but, full range for my application will be linear down to 30hz.
5th element 4th March 2019 01:50 AM
If it needs to be high efficiency then it's going to be pretty big.
Does it need to be high efficiency or just able to hit 114dB @ 30Hz, in what I'm assuming is 4pi radiation.
So essentially you want to hit 120dB at 30Hz at one meter before any diffraction and cabinet effects come into it.
Tromperie 4th March 2019 02:10 AM
Dr Earl Geddes, a member here, has designed and use to sell such beasts.
GedLee LLC
GedLee LLC
GedLee LLC
conanski 4th March 2019 03:00 AM
Quote:
Originally Posted by camplo (https://www.diyaudio.com/forums/multi-way/334757-cover-spectrum-spl-low-distortion-2-a-post5717257.html#post5717257)
Lousy. You need a 3 way.
norman bates 4th March 2019 03:36 AM
eh, my double 15's would run 30-750hz, scrolled active crossover up to 1khz when trying to crack the windows...........
The double 15's had shorting rings though, it helped.
cspieker 4th March 2019 03:52 AM
My horn system is much like what you are describing. I never would have expected a sub driver to cover up to 500hz, but it does nicely. The horn is very high sensitivity, but the woofer obviously is not. You get SET magic up top with real power down low. I love electronic music. Saw James Blake live and it's great fun to recreate the experience in my listening room, albeit with much better bass quality than live.
the "SPIEKER" my almost 20 year prototype finally done
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
Wiki
