I was searching for info on a CDP on the ole' net..and I came across this. A DAC list. Wow. Mods, please erase if you feel it is not a resource you want around, or if it is here already....
CD-players D/A converters
ACOUSTIC RESEARCH CD-07 SAA7220
ACCUPHASE DP65 8x PCM1702 (4/ch)
ACCUPHASE DP85 AD1853
ACCUPHASE DP90 PCM63
ADC CD 250XR PCM54
AKAI CD37 PCM67P
AKAI CD55 AD1856
AKAI CD57 PCM67P-J
AKAI CD69 PCM63
AKAI CD73 PCM56
AKAI CD93 PCM56
AKAI CD-M839 PCM56
ALBA CD420 PCM54
ALCHEMIST NEXUS APD32A 2x TDA1549
AMC CD60 PCM1716
AMC CD8A MN6474 (Technics MASH)
AMC CD8B PCM1716
ANTHEM CD1 PCM1702
ARCAM ALPHA TDA1541A
ARCAM ALPHA 5 TDA1541
ARCAM ALPHA 5 PLUS TDA1541A
ARCAM ALPHA 6 SM5864
ARCAM ALPHA 7 PCM1710
ARCAM ALPHA 7SE PCM1716
ARCAM ALPHA 8 SM5864AP
ARCAM ALPHA 9 dCS RingDAC
ARCAM ALPHA PLUS TDA1541A
ARCAM CD72 PCM1716
ARCAM CD92 dCS RingDAC
ARCAM DELTA 70.2 TDA1541AS1 (single crown)
ARCAM DELTA 70.3 SAA7350
ARCAM DELTA 110 2x SAA7321 (1/ch)
ARCAM DELTA 110.2 2x PCM67P-J (Sync Lock)
ARCAM DELTA 270 PCM69
ARCAM DELTA BLACK BOX 1 TDA1541A
ARCAM DELTA BLACK BOX 2 TDA1541A
ARCAM DELTA BLACK BOX 3 4x SAA7321 (2/ch)
ARCAM DELTA BLACK BOX 5 2x PCM67PJ (Sync Lock)
ARYE CX-7 PCM1738
ARYE D-1 PCM1704
AUDIO ALCHEMY ENGINE v3.0 AD1862
AUDIO ANALOGUE MAESTRO AD1855
AUDIO INNOVATIONS ALTO PCM1716
AUDIO NOTE CD-1 PCM1710
AUDIO NOTE CD-2 AD1865
AUDIO NOTE DAC-3 PCM63
AUDIO RESEARCH CD1 SAA7341
AUDIOLAB 8000 CD CS4329
AVI SC2000MC PCM63
BLAUPUNKT CP2650 PCM54
BLAUPUNKT CP2990 PCM56P
CAMBRIDGE AUDIO CD1 TDA1541
CAMBRIDGE AUDIO CD2 4x TDA1541
CAMBRIDGE AUDIO CD3 TDA1541A
CAMBRIDGE AUDIO CD4SE CS4327
CAMBRIDGE AUDIO CD6 TDA1305T
CAMBRIDGE AUDIO D500 CS4327
CARVER SD/A 450 MN6474
C.E.C. 530CD2 Y3015
C.E.C. 680CD LC7881
CONDOR CD950 YM3020
CONSONANCE CD 120 CS4396
COPLAND CDA277 PCM63
COPLAND CDA288 PCM63-K
CREEK CD50 MkII CS4396
CROWN AVC-9500 AD1864
CROWN CD2111R LC7881
CYRUS CD7 PCM1716
CYRUS dAD1 TDA1311
CYRUS dAD3 TDA1305
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
DENON DA-500 PCM1702
DENON DCD-435 PCM1716E
DENON DCD-480 PCM61
DENON DCD-485 PCM1735
DENON DCD-500 PCM54
DENON DCD-580 PCM67P
DENON DCD-590 PCM61
DENON DCD-615 PCM61P
DENON DCD-635 PCM61P
DENON DCD-650F PCM1700P
DENON DCD-655 PCM1702
DENON DCD-660 2x PCM61
DENON DCD-680 PCM69A
DENON DCD-685 PCM1702
DENON DCD-690 PCM61
DENON DCD-695 PCM61
DENON DCD-700 PCM54HP
DENON DCD-725 PCM61P-L
DENON DCD-735 PCM61
DENON DCD-755AR PCM1702
DENON DCD-800 PCM54
DENON DCD-820 PCM56
DENON DCD-890 PCM61P
DENON DCD-920 PCM61
DENON DCD-980 PCM61P
DENON DCD-1015 PCM61P
DENON DCD-1100 PCM53JP-V
DENON DCD-1400 PCM56
DENON DCD-1420 PCM54HP
DENON DCD-1450AR PCM1702
DENON DCD-1460 PCM61P
DENON DCD-1500 PCM54HP-K
DENON DCD-1500mk2 PCM56P-J
DENON DCD-1520 PCM64
DENON DCD-1530 PCM61
DENON DCD-1550R PCM61
DENON DCD-1550AR PCM61P
DENON DCD-1560 PCM1701
DENON DCD-1650R PCM1702
DENON DCD-1800 PCM53
DENON DCD-2560 4x AD1862
DENON DCD-2700 4x PCM1702J
DENON DCD-S10/3000 PCM1702J
DENON DCD-3300 PCM56P-K
DENON DCD-3520 PCM64
DENON DCD-3560 PCM58P-K
DENON DCD-S1 PCM1702
DENON DCM-280 PCM1748
DENON RCD-100 PCM1710
DENON UCD-F10 PCM61
DIORA CD-502 TDA1543
DUAL CD130 CX20017
DUAL CD20 PCM53
EXPOSURE CD TDA1545A
EZO FOG STAGE3 AD1853
FISCHER AD935 LC7881
FISCHER Z1 PCM58
GRUNDIG CD103 LC7881
GRUNDIG CD9000 TDA1541A
HARMAN KARDON HD200 YM3020
HARMAN KARDON HD500 PCM53
HARMAN KARDON HD710 MN6474
HARMAN KARDON HD720 PCM1710
HARMAN KARDON HD730 SAA7350
HARMAN KARDON HD740 PCM1702U
HARMAN KARDON HD750 PCM1732
HARMAN KARDON HD760 PCM1702
HARMAN KARDON HD7225 MN6474
HARMAN KARDON HD7300 PCM61
HARMAN KARDON HD7325 MN6474
HARMAN KARDON HD7525 PCM61P
HELIOS MODEL1S CS4328 (36 bit, ETNA)
HELIOS MODEL2S CS4328 (36 bit, ETNA)
HELIOS MODEL3S CS4328 (36 bit, ETNA)
HELIOS STARGATE CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE PCM67
HIGH TECH GOLDLINE CX904 YM3020
JOLIDA JD-100A PCM1716E
JVC XL V22 PCM54
JVC XL V221 LC7881
JVC XL V250BK PCM56
JVC XL V311BK MN6471
JVC XL V464 MN35500
JVC XL V1100 PCM54
KENWOOD DP47 TD6720N
KENWOOD DP460 TD6709N
KENWOOD DP850 CX20152
KENWOOD DP-880SG PCM56P
KENWOOD DP1080 LC78620E
KENWOOD DP1100D CX20152
KENWOOD DP1510 PCM56
KENWOOD DP2000 CX20152
KENWOOD DP2010 PCM56P
KENWOOD DP2080 LC78620E (LC78820)
KENWOOD DP3080 SM5864
KENWOOD DP4090 KAN03
KENWOOD DP5020 PCM1701P
KENWOOD DP5090 MN35502 JVC
KENWOOD DP7002 PCM1702
KENWOOD DP7020 new PCM1701P
KENWOOD DP7030 CXD2552
KENWOOD DP7060 TDA1547
KENWOOD DP7090 8x PCM1702
KOREA CHINA CD 022 KDA0316LN
KOREA HCD 630 Y3015
KRELL KAV280 PCM1704
LINN GENKI PCM1723
LUXMAN D 102 TD6709N
LUXMAN D 103 PCM1701
LUXMAN D 112 1x PCM56 (s/h)
LUXMAN D2 92 LC7881
MARANTZ CD7 TDA1541AS2 (double crown)
MARANTZ CD10 TDA1547
MARANTZ CD11LE TDA1547
MARANTZ CD11mkII TDA1547
MARANTZ CD14 TDA1547
MARANTZ CD15 TDA1547
MARANTZ CD16D TDA1547
MARANTZ CD17mkII TDA1547
MARANTZ CD17mkIII PCM1716E
MARANTZ CD19 SM5872
MARANTZ CD34 TDA1540
MARANTZ CD38 TDA1545
MARANTZ CD40 TDA1541A
MARANTZ CD42 SAA7350
MARANTZ CD43 SM5872BS
MARANTZ CD45 TDA1540
MARANTZ CD48 TDA1549
MARANTZ CD50 TDA1541
MARANTZ CD52 SAA7321GP
MARANTZ CD52SE SAA7350
MARANTZ CD53 SM5872BS
MARANTZ CD56 TDA1541
MARANTZ CD60 TDA1541A
MARANTZ CD63 SM5872BS
ADC CD 250XR PCM54
AKAI CD37 PCM67P
AKAI CD55 AD1856
AKAI CD57 PCM67P-J
AKAI CD69 PCM63
AKAI CD73 PCM56
AKAI CD93 PCM56
AKAI CD-M839 PCM56
ALBA CD420 PCM54
AMC CD60 PCM1716
AMC CD8B PCM1716
ANTHEM CD1 PCM1702
ARCAM CD72 PCM1716
ARYE CX-7 PCM1738
ARYE D-1 PCM1704
AVI SC2000MC PCM63
C.E.C. 530CD2 Y3015
C.E.C. 680CD LC7881
CONDOR CD950 YM3020
CYRUS CD7 PCM1716
CYRUS dAD1 TDA1311
CYRUS dAD3 TDA1305
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
DENON DCD-480 PCM61
DENON DCD-500 PCM54
DENON DCD-590 PCM61
DENON DCD-690 PCM61
DENON DCD-695 PCM61
DENON DCD-735 PCM61
DENON DCD-800 PCM54
DENON DCD-820 PCM56
DENON DCD-920 PCM61
DENON UCD-F10 PCM61
DUAL CD130 CX20017
DUAL CD20 PCM53
FISCHER Z1 PCM58
JVC XL V22 PCM54
JVC XL V221 LC7881
JVC XL V250BK PCM56
JVC XL V464 MN35500
JVC XL V1100 PCM54
KOREA HCD 630 Y3015
LINN GENKI PCM1723
LUXMAN D2 92 LC7881
MARANTZ CD19 SM5872
Part Deux
MARANTZ CD63mkII SM5872
MARANTZ CD63mkII KI SM5872
MARANTZ CD63SE SM5872BS
MARANTZ CD65 TDA1541
MARANTZ CD65mkII TDA1541A
MARANTZ CD67 SM5872
MARANTZ CD67SE SM5872
MARANTZ CD67mkII OSE SM5872
MARANTZ CD72 SAA7350
MARANTZ CD72mkII SE TDA1547
MARANTZ CD73 2x TDA1540
MARANTZ CD74 2x TDA1540
MARANTZ CD75mkII TDA1541A
MARANTZ CD80 TDA1541
MARANTZ CD84 TDA1540
MARANTZ CD85 TDA1541
MARANTZ CD94 TDA1541A
MARANTZ CD94mkII 2x TDA1541AS1 (single crown)
MARANTZ CD4000 TDA1545
MARANTZ CD5000 TDA1549
MARANTZ CD6000 SM5872
MARANTZ CD6000KI SM5872
MARANTZ CD6000OSE 2x SM5872
MARANTZ CDA94 TDA1541
MARK LEVINSON No. 36 PCM1702 (vagy PCM1704)
MARK LEVINSON No. 390S AD1853
MERACUS TANTO CS4327KS
MERIDIAN 208 2x SAA7321
MERIDIAN 508 CS4329
MICROMEGA LEADER SAA7321GP
MICROMEGA LOGIC SAA7321
MICROMEGA PREMIUM18 CS4327
MICROMEGA STAGE2 SAA7321GP
MICROMEGA STAGE6 TDA1305
MISSION dAC5 TDA1547
MISSION dAD3 TDA1305
MISSION PCM4000 TDA1541
MITSUBISHI DP109 PCM56
MITSUBISHI MC5100 PCM56
MUSICAL FIDELITY A2 YDC103
MUSICAL FIDELITY DIGILOG TDA1541
MUSICAL FIDELITY E60 YDC103
MUSICAL FIDELITY E624 PCM1716
MUSICAL FIDELITY Tri-Vista PCM1738
MUSICAL FIDELITY X-Ray PCM1716
MYRYAD T-10 CS4327
MYRYAD T-20 CS4327
MYRYAD MC100 CXD2565
NAD 502 MN6474AM
NAD 510 SAA7350
NAD 512 MN6474
NAD 522 PCM1710
NAD C541i PCM1710
NAD 5100 PCM56
NAD 5325 LC7881
NAD 5425 MN6471M
NAD C520 PCM1710
NAD S500 CS4390
NAIM AUDIO CD1 TDA1541
NAIM AUDIO CD2 TDA1541
NAIM AUDIO CD3 TDA1541
NAIM AUDIO CD3.5 TDA1305
NAIM AUDIO CD5 TDA1305
NAIM AUDIO CDI TDA1541AS1 (single crown)
NAIM AUDIO CDS11 PCM1702K
NAKAMICHI CD PLAYER 1 PCM1700P
NAKAMICHI CD PLAYER 4 AD1864N
NAKAMICHI MB 4 LC78840
NAKAMICHI MB 5 LC78840
NAKAMICHI CDP 2E TDA1541A
NAKAMICHI OMS 1E PCM56
NAKAMICHI OMS 4E PCM54
NAKAMICHI OMS 5E TDA1540
NAKAMICHI OMS 7E PCM54
NEC CD610 PCM54
ONKYO C-1E Integra 2x TDA1547
ONKYO DX-704 MN6472 (Technics MASH)
ONKYO DX-6430 YM3020
ONKYO DX-6470 PCM56
ONKYO DX-6550 Integra TC9219 (ONKYO 8D-3170-1)
ONKYO DX-6570 PCM58
ONKYO DX-6620 LC7881
ONKYO DX-6850 Integra 2x SM5861
ONKYO DX-7011 TC9237
ONKYO DX-7211 SM5874
ONKYO DX-7222 TC9268P
ONKYO DX-7333 TC9268P
ONKYO DX-7500 ONKYO 8S-3380-1
ONKYO DX-7711 Integra 2x SM5864AP
ONKYO DX-7911 Integra 2x SM5864AP
ORELLE CD100 TDA1541
PARASOUND CD M839 PCM56
PARASOUND C/DP1000 PCM67
PHILIPS CD-80 TDA1541
PHILIPS CD-85M TDA1541
PHILIPS CD-94M TDA1541
PHILIPS CD-100 TDA1540
PHILIPS CD-101 TDA1540
PHILIPS CD-104 TDA1540
PHILIPS CD-200 TDA1540
PHILIPS CD-202 TDA1540
PHILIPS CD-204 TDA1540
PHILIPS CD-210 TDA1543
PHILIPS CD-300 2x TDA1540
PHILIPS CD-303 2x TDA1540
PHILIPS CD-304 TDA1540
PHILIPS CD-304 MkII TDA1541
PHILIPS CD-350 2x TDA1540
PHILIPS CD-380 TDA1543
PHILIPS CD-460 TDA1541
PHILIPS CD-465 TDA1541
PHILIPS CD-471 TDA1541
PHILIPS CD-472 TDA1541
PHILIPS CD-473 TDA1541
PHILIPS CD-480 TDA1543
PHILIPS CD-482 TDA1543
PHILIPS CD-581 TDA1541
PHILIPS CD-582 TDA1541
PHILIPS CD-604 TDA1543
PHILIPS CD-610 TDA1543
PHILIPS CD-614 TDA1543
PHILIPS CD-615 TDA1543
PHILIPS CD-620 TDA1541
PHILIPS CD-624 SAA7323
PHILIPS CD-630 TDA1541
PHILIPS CD-634 SAA7321
PHILIPS CD-640 TDA1541
PHILIPS CD-650 TDA1541
PHILIPS CD-670 TDA1541
PHILIPS CD-721 TDA1545A
PHILIPS CD-723 TDA1545
PHILIPS CD-750 SAA7350 (vagy TDA1549)
PHILIPS CD-751 TDA1549
PHILIPS CD-753 TDA1549
PHILIPS CD-782 TDA1541
PHILIPS CD-820 TDA1541A
PHILIPS CD-850 TDA1541
PHILIPS CD-880 TDA1541AS1 (single crown)
PHILIPS CD-910 SAA7341GP
PHILIPS CD-911 SAA7341GP
PHILIPS CD-930 SAA7350
PHILIPS CD-931 SAA7350
PHILIPS CD-940 SAA7350S
PHILIPS CD-950 TDA1547
PHILIPS CD-951 TDA1547
PHILIPS CD-960 TDA1541
PHILIPS CDR-950 AD1855
PHILIPS DAC-960 TDA1541A
PHILIPS LHH-100 TDA1547
PHILIPS LHH-500 TDA1547
PHILIPS LHH-600 TDA1547
PHILIPS LHH-800 TDA1547
PHILIPS LHH-1000 TDA1541
PHILIPS MAGNAVOX CDB-560 TDA1541
PHILIPS MAGNAVOX CDB-650 TDA1541
PINK TRIANGLE NUMERAL TDA1305T
PIONEER DV-717 PE8001A
PIONEER PD-52 PD2028
PIONEER PD-75 PD2028A (vagy PD2028B)
PIONEER PD-77 PD2028B
PIONEER PD-93 PD2028A
PIONEER PD-95 PD2028A (vagy PD2028B)
PIONEER PD-204 PD2026B
PIONEER PD-4500 PCM1700
PIONEER PD-4550 PCM1700P
PIONEER PD-5100 PD0034
PIONEER PD-5300 PCM56
PIONEER PD-5700 PD2026A
PIONEER PD-7300 PCM58P
PIONEER PD-7700 PD2026A
PIONEER PD-8500 PCM63P
PIONEER PD-9300 PCM58
PIONEER PD-9700 PD2028A
PIONEER PDR-04 AKM4321
PIONEER PDR-609 PCM1716
PIONEER PDR-W739 PCM1716
PIONEER PDR-W839 PCM1716
PIONEER PD-S06 PCM1702J
PIONEER PD-S502 PD2026B
PIONEER PD-S505 PD2029A
PIONEER PD-S507 PE8001A
PIONEER PD-S605 PD2029A
PIONEER PD-S703 PD2029A
PIONEER PD-S707 PE8001A
PIONEER PD-S801 PD2028
PIONEER PD-S802 PD2028B
PIONEER PD-S901 PD2028B
PIONEER PD-S904 PD2028B
PRIMARE CD31 4x PCM1704K
PRIMARE D20 AKM4324
PRIMARE D302 4x PCM1702
PROCEED PCD2 PCM58P
PROTON AC423 LC78820
PROTON AC424 TDA1311A
QUAD66 TDA1541A
QUAD77 CS4328
REGA PLANET PCM1710U
REVOX B225 TDA1540
REVOX B226 TDA1541
REVOX C221 SAA7310
ROKSAN ATTESSA DP3P CS4328
ROKSAN CASPIAN TDA1305
ROTEL RCD-02 PCM1732
ROTEL DCM-9PRO PCM63
ROTEL RCD-855 TDA1541
ROTEL RCD-856BX SAA7323
ROTEL RCD-865BX SAA7323
ROTEL RCD-945AX SAA7341GP T
ROTEL RCD-955AX TDA1541A
ROTEL RCD-955 TDA1541
ROTEL RCD-961 PCM1732U
ROTEL RCD-965BX SAA7323GP T
ROTEL RCD-970BX TDA1305T
ROTEL RCD-971 PCM63
ROTEL RCD-975 TDA1305T
ROTEL RCD-991 PCM63P
ROTEL RCD-1070 PCM1732
SANSUI CD V1000 PCM56
SANYO CP489 LC7881
SEG CD200 YM3020
SHARP DX112 IR 3K16BM
SHARP DX650 LC7880
SHERWOOD CD1 TDA1547
SHERWOOD CD1060C D6372 CX
SHERWOOD CD1160R PCM56
SHERWOOD CD1192R YM4113B
SHERWOOD CDC2000C µPD6376
SHERWOOD CDC2010RC µPD6376
SHERWOOD CD4030R SAA7350BS
SIMAUDIO MOON ECLIPSE 4x PCM1704K
SONIC FRONTIERS SFCD1 UltraAnalog D20400A
SONY CDP-40 1x PCM54 (s/h)
SONY CDP-101 CX20017
SONY CDP-222ES PCM56P J
SONY CDP-222ESD 1x TDA1541
SONY CDP-227ESD TDA1541
SONY CDP-228ESD PCM58P
SONY CDP-302ES CX20152
SONY CDP-303ESII CX20152
SONY CDP-313 CXD2565M
SONY CDP-315 CXD2565M
SONY CDP-333ESA CXD2562
SONY CDP-333ESD TDA1541
SONY CDP-333ESJ CXD2562
SONY CDP-337ESD TDA1541
SONY CDP-338ESD 2x PCM58P
SONY CDP-497 CXD2561
SONY CDP-501ES CX20017
SONY CDP-502 PCM54
SONY CDP-502ES CX20152
SONY CDP-502ESII PCM53JP-V
SONY CDP-520ESII CX20152
SONY CDP-552 PCM54
SONY CDP-552ESD CX20152
SONY CDP-553ESD PCM53JP-V K
SONY CDP-555ESA CXD2562
SONY CDP-555ESD TDA1541A
SONY CDP-555ESJ CXD2562
SONY CDP-557ESD PCM58P
SONY CDP-620 PCM54
SONY CDP-650 PCM54
SONY CDP-701ES CX20017
SONY CDP-707ESD PCM58P
SONY CDP-777ESA CXD2562Q
SONY CDP-M95 TDA1541
SONY CDP-MS1 CXD8594 + CXA8042AS
SONY CDP-R3 + DAS-R1a CXD2552Q + CXD2552
SONY CDP-X229ES CXD2562Q
SONY CDP-X3000 CXD2562Q + CXA8042AS
SONY CDP-X303ES CXD2562Q
SONY CDP-X5000 CXD2562 + CXA8042
SONY CDP-X505ES CXD2562Q
SONY CDP-X33ES CXD2552Q
SONY CDP-X55ES CXD2552
SONY CDP-X777ES CXD2552BQ
SONY CDP-X779ES CXD2562
SONY CDP-X77ES CXD2552
SONY CDP-X7ESD PCM58P S
SONY CDP-X900 CXA8042
SONY CDP-XA20ES CXD8505BQ + CXA8042AS
SONY CDP-XA30ES CXD2562Q + CXA8042AS
SONY CDP-XA50ES CXA8042AS
SONY CDP-XA55ES CXD8594Q + CXA8042S
SONY CDP-XA5ES CXD2562Q + CXA8042AS
SONY CDP-XA7ES CXD2562 + CXA8042AS
SONY CDP-XB920 CXD8715 + CXA8355
SONY CDP-XB720E CXD8735N
SONY CDP-XB930 CXD8735N
SONY CDP-XE300 CXD8567
SONY CDP-XE330 CXD2529Q
SONY CDP-XE900 CXD8505 + CXA8055
SONY DAS-R1 2x TDA1541AS1 (single crown)
SONY PLAYSTATION SCPH-1002 AKM AK4310VM or AK4310AVM (late)
SONY PLAYSTATION SCPH-5502 AKM AK4310AVM
SONY PLAYSTATION SCPH-5552 AKM AK4310AVM
SOUND WAVE CD1100 LC7881
SUDGEN OPTIMA TDA1543
SUDGEN SDA-1 TDA1541
SUDGEN SDT-1 TDA1541AS1 (single crown)
T+A CD1210R SM5864AP
TAG McLAREN CD20R CS4329
TALK ELECTRONICS THUNDER 3 CS4390
TASCAM CD201 MN6474
TEAC CPD3450SE YDC103
TEAC PD155mk2 Y3015
TEAC PD160 TC9218F
TEAC PD365 YM7121B
TEAC VRDS 7 SAA7350
TEAC VRDS 8 PCM1702
TEAC VRDS 9 PCM1702
TEAC VRDS 10SE TDA1547
TEAC VRDS 25 AD1862J
TEAC ZD5000 PCM53
TECHNICS SL-P1 PCM53
TECHNICS SL-P2 PCM53
TECHNICS SL-P110 PCM54HP
TECHNICS SL-P120K E PCM54HP
TECHNICS SL-P272A MN6474
TECHNICS SL-P555 MN6471
TECHNICS SL-P770 2x PCM56P + 2x PCM56P-J
TECHNICS SL-P990 4x PCM56P-J
TECHNICS SL-P999 4x PCM56P-J
TECHNICS SL-P1200 PCM54HP
TECHNICS SL-PG480A MN662713
TECHNICS SL-PJ28A MN6477
TECHNICS SL-PS670D MN6474
TECHNICS SL-PS700 MN6474
TECHNICS SL-PS770A MN64733
THETA DSP PCM67
THOMSON LAD300 TD6720N
THULE CD100 CS4303
THULE SPIRIT PCM1715U
TOSHIBA XR40 TD6705AP
UHER UCD-210 LC7882
UNIVERSUM CD4682 PCM56
USHER CD-100 PCM1732
WADIA 23 AD1865
WADIA 850 PCM1702
WADIA 860 4x PCM1702
WADIA 861 4x PCM1704
YAMAHA CD-2 PCM53
YAMAHA CD-3 PCM53
YAMAHA CD-2000 PCM54HP
YAMAHA CDX-3 PCM54
YAMAHA CDX-410 PCM56
YAMAHA CDX-420 PCM56
YAMAHA CDX-470 YDC103
YAMAHA CDX-480 MN66271
YAMAHA CDX-490 MN66271R
YAMAHA CDX-580 YAC514
YAMAHA CDX-590 YAC514
YAMAHA CDX-593 YAC514
YAMAHA CDX-700 PCM56
YAMAHA CDX-810 2x PCM56J
YAMAHA CDX-880 YAC514
YAMAHA CDX-890 YAC514
YAMAHA CDX-893 YAC514
YAMAHA CDX-900 PCM56
YAMAHA CDX-993 YAC514F
YAMAHA CDX-1100 PCM56
YAMAHA CDX-2020 PCM58
I have a feeling some of you may be buying more junk off Ebay in the near future....
MARANTZ CD67 SM5872
MERIDIAN 508 CS4329
MYRYAD T-10 CS4327
MYRYAD T-20 CS4327
NAD 502 MN6474AM
NAD 510 SAA7350
NAD 512 MN6474
NAD 522 PCM1710
NAD C541i PCM1710
NAD 5100 PCM56
NAD 5325 LC7881
NAD 5425 MN6471M
NAD C520 PCM1710
NAD S500 CS4390
NEC CD610 PCM54
ONKYO DX-6470 PCM56
ONKYO DX-6570 PCM58
PRIMARE D20 AKM4324
PROCEED PCD2 PCM58P
QUAD66 TDA1541A
QUAD77 CS4328
REVOX B225 TDA1540
REVOX B226 TDA1541
REVOX C221 SAA7310
ROTEL RCD-971 PCM63
SANYO CP489 LC7881
SEG CD200 YM3020
SHARP DX650 LC7880
SONY CDP-502 PCM54
SONY CDP-552 PCM54
SONY CDP-620 PCM54
SONY CDP-650 PCM54
TASCAM CD201 MN6474
TEAC PD155mk2 Y3015
TEAC PD160 TC9218F
TEAC PD365 YM7121B
TEAC VRDS 7 SAA7350
TEAC VRDS 8 PCM1702
TEAC VRDS 9 PCM1702
TEAC ZD5000 PCM53
THETA DSP PCM67
THULE CD100 CS4303
UHER UCD-210 LC7882
WADIA 23 AD1865
WADIA 850 PCM1702
YAMAHA CD-2 PCM53
YAMAHA CD-3 PCM53
YAMAHA CDX-3 PCM54
No need to republish the list, I has been already mentioned here before:
http://www.freeweb.hu/mestertuning/dac.php
A list with some 1.800 entries is available at
http://www.marantzphilips.nl/index.asp?strBrand=Various&strPage=Daclist
(also mentioned on these forums before)
_
_
[b]pilli[/b] said:A list with some 1.800 entries is available at
_
On this site the D/A converter list contains mistakes.
The original D/A Converter List has been created by me.
And I have placed it here:
www.vasiltech.nm.ru/files/cd-players/CD-Player-DAC-Transport.htm
And I periodically update it and I correct it from mistakes.
Vasily aka VasilTech
(Belarus, Minsk)
Kenwood DP5090 error ?
Hello,
sorry but I don't think that KAN-05 on Kenwood DP5090 is a National MN35502
I see that everywhere, but if you compare the datasheet of a MN35502 and the KAN-05 in the DP5090 SM, I don't think this is the same IC
MN35502 Datasheet
DP5090 Service Manual
Pascal
Hello,
MN35502 Datasheet
Pascal
Can anybody explain what is the meaning of vagy?
someone who wont eat dead meat or dairyproducts
(Belarus, Minsk)
your list also has mistakes:
The Proceed PCD2 and 3 have the Philips CDM1-MKII transport.
Re: vagy
vagy means or in Hungarian (the list appeared first on the http://www.freeweb.hu/mestertuning/dac.php site)askchan said:Can anybody explain what is the meaning of vagy?
URL is death. Please let me know the currently webaddress - thank you.On this site the D/A converter list contains mistakes.
[B][I][U][url]www.vasiltech.nm.ru/files/cd-players/CD-Player-DAC-Transport.htm[/U][/I][/B][/url]
(Belarus, Minsk)
I know, that eight years have gone, since, but that's the point! The list you mention results in a 404 error. It's offline! A lot of these resources are privately owned and thus can go away at any time. Only one of the links offered here, is still in function.No need to republish the list, I has been already mentioned here before:
- Digital Line Level
- DAC List
