How to calculate fuse values to protect Primary/Secondary windings....please!!
How to calculate fuse values to protect Primary/Secondary windings....please!! Please consider donating to help us continue to serve you.
Old 14th February 2020, 07:07 AM   #11
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
Is that JLH amp? I always put fuses on the secondary side on the AC going into the bridge on amps I build. Some say it's not needed but the amount of times I've had fuses blow whilst getting a project up and running... Most commercial 70's amps have two such fuses on the PCB.
The way I understand it is the primary fuse is there to protect in case of a catastrophic short, secondary fuses to protect in case of partial shorts.
I tend to use a thermistor and or soft start circuit and slightly underated slo blo fuse on the primary, measure the sec current draw & put suitable fast fuses on each rail.
I was also advised to put a fuse on the ground, but can't remember the where's and whyfors.
Use an analogue meter to measure inrush current on the primary.
Andy.
Old 14th February 2020, 03:24 PM   #12
tonewheelkev is offline tonewheelkev  United Kingdom
Yes Andy...it's the JLH 80W monoblock!
Reading through the JLH manual....the only reference to fuses is to the 5A (at least!) one that should be in the wall plug! (suggests to me...at any rate...that a 3A fuse at the wall, would be tripped by the inrush.
Oddly...there are no fuses present inside the case.
If I was to go for a 3.0A slo-blo on the primary...would that be a good starting point? (Just narrowing the discussion to my task!)
Also....will be replacing all 4 reservoir caps(2 x Monoblocks)
These are 4700uf/63v presently.
Is there any advantage in up-rating replacements to...say...10000uf/80v...or should I just stick to original spec.?
Old 15th February 2020, 08:03 AM   #13
"Yes Andy...it's the JLH 80W monoblock!" Is this built with the original PCB's then available for sale? I have most of the ETI's for this period and have been looking at building this amp myself, however T03 mosfets are getting hard to find and expensive, PNP T03's rare as rocking horse s**t. For those prices I could buy a tooob. Whinge over.
3A slo should be fine, better under rated than over rated. Re, replacing the reservoir caps, what's your mains tfmr like? Is it a decent brand like ILP/Antrim and at what VA is it rated? If you increase/double the capacitance, your tfmr has to supply that current through your BR, if it's not up to the job it will get hot and possibly the insulation will breakdown.
I recently recapped a HH S500D, the rails were over 63v, so I bought 80v rated caps, therefore measure the voltage on your rails. To find out if your tfmr is up to it, load it with some big resistors, lightbulbs or whatever & do the maths. At a rough guess you need about 3/4A @ 25v to get 80w, so 63/3 = 21, so two 20r 50w resistors should do the job. If your tfmr runs cool with no noise, reduce the loads till V falls by 10%, that's your tfmr current limit.
Andy.
Old 16th February 2020, 02:08 PM   #14
Thanks Diabolical Artificer.
Plan to get these up to sppeed for myself...so not selling on I'm afraid.
Transformers are bespoke from Tiger-Toroids...
Had to compromise a little on power rating, in order to get right physical dimensions.
I understand these to be rated as 280VA 50-0-50...as opposed to the original 300VA 50-0-50.
Searching around on t'web....found that there was an alternative transformer spec....being 225VA 50-0-50...so figured the 280VA to be in the right 'ball park'
Although confident in terms of the arithmetic...I lack the capacity for the 'hands on' interventions that you refer to in your para. 3
Old 16th February 2020, 02:27 PM   #15
Mooly's Avatar
A 250 to 300VA toroid is going to need something of the order of a T3.15A or T4A for the primary, otherwise you may get nuisance blowing at switch on if the conditions happen to be right.
(Inrush current has more to do with both how magnetised the core is, and that is an unknown as it depends totally on what point in the AC cycle the power was removed when it was last turned off and also the point on the cycle when power is turned on again)
The mains plug fuse needs to be a 5A for the same reasons.
300VA doesn't really need a slow start imo although these things have become fashionable in recent years. Above 300VA and its probably worth looking into.
Secondary fusing depends on the load expected and the inrush current to the reservoir caps. Again a lot of unknowns because even a little wiring resistance from transformer to bridge and from bridge to caps can dramatically reduce peak currents.
Quite a few big commercial amps don't even fuse the secondaries and here they assume that a major overload will saturate the transformer and cause the primary fuse to blow.
Old 16th February 2020, 09:43 PM   #16
Thanks Mooly....will be stocking up on 3 to 4A fuses at my local RS counter this week!
Have now decided just to fuse the Primary....keep things simple!!
Any more thoughts out there on replacing/upgrading the reservoir caps?
The Hart Kit parts list gives them as 4700uf/63V....but that was 20+ years ago, and caps have become physically smaller (and cheaper?)
Wondered if going to a higher level of capacitance would be worth it...I'm having to replace all 4 caps anyway...so now is the time!!
Old 17th February 2020, 08:01 AM   #17
Mooly's Avatar
I'm not a huge fan of oversized caps tbh. They give the transformer a hard time when the rails are heavily loaded.
The transformer has to top the caps up every half cycle, a bigger cap means the same energy still has to be put back in, but now over a shorter space of time. Why shorter? Because the oversized cap has caused the voltage to sag less between peaks and so the bridge rectifier will not conduct until that voltage point is crossed. That means the transformer/diode current peaks are that much higher per half cycle. A regulated supply means you can relax the cap value somewhat, as long as the ripple rating is sufficient.
I wouldn't go higher than say 6800uF in total per rail for that PSU.
Old 18th February 2020, 03:25 PM   #18
Thanks Mooly.....for the recommendation, and the reasoning behind it!
Much appreciated
How to calculate fuse values to protect Primary/Secondary windings....please!!Hide this!Advertise here!
In what situation would a fuse on the primary windings help? Fusion916 Solid State 16 15th October 2013 04:55 PM
10k and 6k primary windings on OPT. Use for UL? rongon Tubes / Valves 3 2nd November 2011 06:53 PM
Multiple primary windings Sylvania Tubes / Valves 2 23rd July 2007 09:58 AM
transformer primary windings Q AndrewT Power Supplies 6 28th October 2006 12:51 PM
cap btween primary and secondary windings? sam9 Power Supplies 8 19th May 2005 07:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
