I'm in the process of building a 6L6 power amplifier (push pull), and I would like to regulate the screen grids. Attached is an idea I had, but I'm not sure if it's a good idea.
I could also swap the 7805 for a MOSFET like an IRF640, if that would be better suited to the task. I calculated that my absolute maximum current draw will be about 75 mA under full load, maybe 100 mA if I run the preamp and phase splitter tubes off it as well.
Thanks for the suggestions.
John
John
Review the minimum current of your gas-tube. Compare to the current of 5V over 16K. I believe the glow will just quit, or be super erratic.
And isn't 0.047u a bit large to put right across a gas-tube?
_IF_ you can find good neon lamps, 1mA in those will provide all the current a MOSFET gate needs.
A MOSFET _is_ the usual approach. (Back in 1978 I had to use a TV sweep transistor.)
Read up on gate resistor and diode or it will go "poof".
