Hi
The following AD1955 DAC board requires AC Power.
AD1955+WM8805+PCM2706 Board Coaxial Fiber Optic USB DAC Board YJ-1 | eBay
The bottom right corner, has 2 connectors:
The left one is labelled: AC9V, AC9V
The right one is labelled: AC15V, 0V, AC15V
Does the user of this board need to supply both of them, or only 1 of them?
And also, why the 9v is Single Rail and the 15v is Dual Rail?
Thank you
Thank you
Oh..You need to supply both as the board is now.
Are there transformers that output both 9v and 15v?
Or does this mean that I will need to get 2 separate transformers for this board?
Yup, you need a transformer or transformers that can supply both. Since you are in the U.S. that would be one transformer with a 120 volt primary with two secondary sections, one with 2 x 9 volt and the second with 15 volt - 0 - 15 volt. Or two separate transformers , each with one of the above configurations. Your eBay seller probably has one specific for that board.
Interesting.Most likely the digital circuit uses the single rail and the audio uses the dual rail, it's good that they use entirely separate supplies
Tho it makes powering it more complicated - you need to find 1 transformer that supplies both 9v and 15v.. (or, get 2 transformers..)
In addition,
let's say I find a transformer that supplies both 9v and 15v,
will it supply both the 9v and 15v using 3 wires? (e.g. 9v,0v,9v, and 15v,0v,15v)
and then I take the 0v only when needed (for the 15v part), and not use it for the 9v part?
Or do I have to find a transformer that specifically gives the 9v in Single Rail, and the 15v in Dual Rail?
You need a transformer with two separate secondaries:
1. 0V-9V - two wires
2. 15V-0V-15V - three wires
There must be no connection between the two secondaries.
If you find a transformer with 9-0-9 and 15-0-15, then you can use it by using either 0-9 or 9-0 (i.e. use two of the three wires for the 9V secondary - do not use the outer two wires as that will give you 18V).
Separate supplies of around these voltages are not unusual so you may be able to find a transformer.
I am glad this is the answer,If you find a transformer with 9-0-9 and 15-0-15, then you can use it by using either 0-9 or 9-0
since it makes it easier to find a matching transformer.
(having to find a transformer that has exactly 3 wires for 15v, and exactly 2 wires for 9v would've been a journey)
Aren't all AC transformers give 3 wires for each output voltage that they have?You need a transformer with two separate secondaries:
There are actually transformers that give 2 wires for an output voltage?
Interesting. So 2-wire output is the more common type,Most transformers have individual (two-wire) secondaries.
I guess the 3-wire output is needed mainly for audio.
But this means using 2 transformers..You can always connect two such secondaries to make a three-wire secondary.
Takes more volume, more weight, and costs more..
You said earlier that from a 3-wire we can take one 2-wire secondary,you cannot split a three-wire secondary into two two-wire secondaries.
e.g. 9v-0v, or 0v-9v (but not the 2 extremes: 9v-9v, because it will double the voltage)
So If we can take 1 pair out of the 3-wires,
what is the reason forwhich we cannot take 2 pairs out of the 3 wires?
(e.g. 9v-0v, and also 0v-9v)
Most transformers have two primaries and two secondaries for flexibility https://www.electronics-tutorials.ws/transformer/multiple-winding-transformers.html
What a great tutorial.
I remember this website from 2-3 years ago,
it really explains well every subject in the field of electricity/electronics.
No, most transformers have two or more secondaries.spaceman5 said:But this means using 2 transformers..
In almost all cases you would need two quite separate secondaries. You cannot have two things both joined and separate - first rule of electronics. People often get in a mess with power supplies trying to break this rule after they have bought the wrong transformer.what is the reason forwhich we cannot take 2 pairs out of the 3 wires?
I see
Thank you DF96 - this really helps.
BTW,
it seems that Transformers are a thing that should not be ordered online, (e.g. on ebay)
since its weight makes the price really expensive.
A similar phenomenon occurs in Solder Tin - due to its weight, it's better to buy it locally.
BTW,
There are transformers available for exactly this type of dac on ebay and aliexpress. One example: R30 Y Type Transformer 40W Power Supply for 1794 4399 4495 DAC Audio Board 723247541166 | eBay
True that it will be unlikely to find a good solution anywhere local.
This is what I have used for similar projects:
AC 220V 30W High Quality Audio R-Core Transformer 15V+15V 9V+9V For Preamp | eBay
It will be very important to identify the center wires of the 15v portion, so as to have the correct arrangement. This can be done with a meter. The 9v will work with the wires in either position.
I will place a fuse onto the primary side as a fire safety measure as well.
Cool,There are transformers available for exactly this type of dac on ebay and aliexpress. One example: R30 Y Type Transformer 40W Power Supply for 1794 4399 4495 DAC Audio Board 723247541166 | eBay
exactly all that's needed.
But like I said, look at the price and the shipping.
Buying it locally should be 1/4 of that (total) price.
Right.Unfortunately, buying transformers (and solder) by some means other than online is rapidly disappearing from most places in most countries.
Electronic components stores are closing,
because people who buy electronic components are usually quite familiar with internet shopping,
and so buy online for much lower prices, and more more variety..
But electrical stuff stores (versus electronics) will probably survive better.
Electrical related stores usually sell bigger things, which are harder and more expensive to ship, and so will retain most of their customers.
I wonder why they both these transformers are not in the nice new toroid shape..This is what I have used for similar projects:
Great, thanks for all the tipsIt will be very important to identify the center wires of the 15v portion, so as to have the correct arrangement. This can be done with a meter. The 9v will work with the wires in either position.
and because the last High Street electronics supplier in the UK was rumoured to only stock two of each item in its shops. Not much good if you want three or more.spaceman5 said:Electronic components stores are closing,
- Power Supplies
- Powering a DAC Board that Requires AC
