Indigo Bash amp in Klipsch Sub10. specs on diac
I stumbled into some great info here on the problems with these amps and hoping some guys are still around? I am trying to spec the problematic D11 diac on the daughter driver board for the PSU mosfets? It is now black and cannot read it.
If anyone has experience with these, I might have a few other questions.
I do understand what a diac is. I am more interested to know if someone has the proper spec for a replacement or the means to test is scrap amp? Someone has mentioned a DB6 which is a 60V trigger, and another mentioned a DB4, which is a 40V trigger. That will make a radical difference in an oscillator circuit.
if we are talking about the same thing, pretty positive that it’s a DB6…at least that is what it is on my BASH amp out of my Focal sub. In case anyone is still confused as to which diac was in there originally. See photo.
