so my idea is to build an all in one integrated amp including a dac. the dac will be powered by salas shunt 5v+ (1543dac) and the amp will be lm1875 15v-0v-15v CLC PSU.
would it be ok to piggyback the salas shunt at the end of 15V+ of the amp psu or would that constant load cause too much harm?
so it would be CLC(amp/salas shunt) for positive supply
and CLC(amp) for the negative supply
or how about CLC(amp)LC(salas)?
thanks for your input in advance.
p.s. i may end up going with a class A amp. in that case does the salas shunt pose less of a problem?
