Hello All,
I am very new to this and trying to put together a dual rail power supply to power Raspberry PI and Hifiberry Digi Pro.
I purchased 4.17uV Ultralow noise DAC power supply regulator 3.3V/5V 1Ax2 from Diyinkh.com ( 4.17uV Ultralow noise DAC power supply regulator 3.3V/5V 1Ax2 - DIYINHK ) and a Talema 70050K 2x7V transformer ( 70050K Talema Group LLC | Transformers | DigiKey ) from Digikey.
I like to use one rail 3.3V for Raspberry and the other 5V to power the HifiBerry Digi-Pro.
Can I use this single transformer in parallel (7V 1.2A each) to power the dual rail regulator (using secondaries seperately)?
Appreciate the knowledge.
It appears that the two regulators are electrically separate, and have no common connection.
If that is so, then each supply circuit can be powered by one secondary that is full wave rectified
and filtered, like this: Solid State Power Amplifier Supply Part 2
The two grounds must be connected together somewhere, as shown in the schematic.
If both the 3.3V and 5V are used on the Rasp etc, they will automagically
be connected to ground where it is best.
Yes, that would be the best point for them to be connected.
Dual Rail Regulator
Thank you so much for the information. I drew a simple schematics (attached) on how to hook the Talema 70050K transformer to the dual rail regulator. Can you check? And let me know if there anything else I need to add for possible ground loop?
Dual Rail Regulator
Will this work?
Appreciate it.
Agree with Rayma.
Probably best not to separately tie anything together as ground, that will only open up pandora's ground loop box.
If both the 3.3V and 5V are used on the Rasp etc, they will automagically be connected to ground where it is best.
Jan
Will this work?
Appreciate it.
