I have the USB DAC connected to the Raspberry Pi. In .asoundrc it's defined as card 2, device 0. Sometimes after rebooting the Pi that USB DAC becomes (aplay -l) card 1, device 0 and audio doesn't go through it. Is there any way to make the USB DAC always use the fixed card number e.g. card 2?
Thanks!
Thanks!
You can often refer to ALSA devices by name. I will use as an example the soundcards on one of my Linux boxes, listed below:
You can see from the above output of the command "aplay -l" that there are four cards, numbered 0 through 3. Let's say I want to use card 2, the Scarlett 6i6. I need to know the name for the device and mode in which I Want to use it. So I issue the command "aplay -L" and search the output. I will just post the relevant part of that output:
If I want to use the Scarlett in 2 channel mode, where I would usually write:
I write
or
Under ALSA these names for the card never change, even if the card number does. Try it on your system.
Code:
charlie@CI327:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 7/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
card 1: PCH [HDA Intel PCH], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 1: ALC892 Digital [ALC892 Digital]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 2: USB [Scarlett 6i6 USB], device 0: USB Audio [USB Audio]
Subdevices: 0/1
card 3: Device [USB Sound Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Code:
front:CARD=USB,DEV=0
Scarlett 6i6 USB, USB Audio
Front speakers
surround21:CARD=USB,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=USB,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=USB,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=USB,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=USB,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
Code:
hw:2,0
Code:
Code:
hw:CARD=USB,DEV=0
Thank you CharlieLaub! It worked when I changed the lines in the .asoundrc from:
to
Best regards
Code:
ctl.!default {
type hw card 2
pcm.plugequal {
type equal;
slave.pcm "plughw:2,0";
Code:
ctl.!default {
type hw CARD=PCM2702,DEV=0
pcm.plugequal {
type equal;
slave.pcm "plughw:CARD=PCM2702,DEV=0";
