2L High Resolution Music .:. free TEST BENCH
Here You can find several multi-channel high resolution tracks.
One of them is a 6 min 1Gb file.
They play fine on VLC or Foobar2000 with the needed plugins.
I would rip them first with a ripping software if the discs are recognized on a computer like DVD audio is. Then I would convert it to multichannel lossless flac.
AC3 or DTS are lossy formats.
Yes, ripping is a good idea, but no, it's impossible to rip (or even play) SACD's using a computer optical drive. You can only rip SACD's with a hacked Playstation3 or hacked Blu-ray player.I would rip them first with a ripping software if the discs are recognized on a computer like DVD audio is.
Yes. The first stage of the rip yields an ISO file which is a bit-for-bit copy of all data on the SACD. The second stage is to extract the individual DSD tracks from the ISO, encapsulated either as .dff files or .dsf files (I recommend .dsf, because tagging is better supported). And at this point you can choose to extract either the stereo tracks, or the multi-channel tracks, or both.ripping is not an option and even if I did it with a hacked PS3 I'm guessing I would still end up with DSD?
If you have suitable hardware to play .dsf files, there's no need to go any further, but in your case you want PCM files, so what's needed is software to convert the .dsf's to PCM - the options are Weiss Saracon DSD (very expensive) or Korg AudioGate, which is free, but apparently you need a Twitter account to enable its export/convert function.
Audacity worked for me with 6 generated sine waves as 5.1 wav . It played back on a pioneer receiver.
I followed Exporting Multitrack Surround Files in Audacity – Terence Eden’s Blog
There is a basic GUI that asks you for the order of tracks before final save.
Regarding DSD-to-PCM conversion, I now recall that foobar2000 is also an option, once the foo_input_sacd component is installed.
I just tested it now - I extracted a multi-channel .dsf file from one of my SACD ISO's, then opened this file in foobar2000, then exported it as a 24bit 88.2khz 6-channel FLAC file.
- PC Based
- Software to record 5.1 SACD
