Hello
At the moment I am using daphile feeding into my m-dac and into my amplifier. I am really satisfied with the quality but recently got a video server, a tranquil pc, mini itx, 4gb ram, i3-2100t 2.5ghz as a media server. I cant use daphile on it as it has its own exclusive o.s. but wondered if there was anything similar I could use on puppy tahr that was of similar quality as an audio player.
thyristor44
thyristor44
Daphile (gentoo linux) uses squeezelite for playback. Puppy tahr is based on Ubuntu 14.04 PuppyLinux: Tahrpup 6.0 CE . There is a package for squeezelite in the official repo Ubuntu – Details of package squeezelite in trusty
Thanks phofman, I am not sure what to do with a deb file in puppy tahr so am finding that out first.Daphile (gentoo linux) uses squeezelite for playback. Puppy tahr is based on Ubuntu 14.04 PuppyLinux: Tahrpup 6.0 CE . There is a package for squeezelite in the official repo Ubuntu – Details of package squeezelite in trusty
I do not use puppy but google suggests it supports regular ubuntu repositories , e.g. Puppy Linux Discussion Forum :: View topic - How to install software from ubuntu repositories?
Why this specific distribution + it seems to be getting rather old (kernel 3.x etc.)?
Can you recommend something, need audiophile audio for flac library but also able to play videos from internet like youtube so they are not so critical for audio quality.Personally I would pick something with easy upgrade path and good hardware support (i.e. relatively new kernel), but good luck.
It depends on the planned usage of that computer and your linux skills.
For me "audiophile audio" means bitperfect delivery from the player to the soundcard. Any linux distribution can do that, it's all about the respective player configuration.
To make sure no software volume is in the chain, I would avoid pulseaudio. That leaves you with direct output to alsa.
Do you want to play youtube in a browser, or using some specialized tool? Latest Firefox supports only PA. Chrome should play to alsa with config option --alsa-output-device List of Chromium Command Line Switches << Peter Beverloo .
Basically any player can play flacs these days. Some people like audacious.
Squeezelite has no GUI, you would have to install whole Logitech Media Server.
Lighter rather well-supported distribution is e.g. Lubuntu. The LTS 16.4 version is supported for 5 years.
Or if you are more advanced, you can pick a rolling-upgrades distribution like Arch linux Arch Linux - Best distro ever? | AkitaOnRails.com
The computer will be used for flac classical library, some youtube from a browser, sound quality less important and again stream live tv from a browser. I do understand alsa a bit. I would like to keep off google and chrome but need it for spotify.
I will have another go at lubuntu and also arch linux. My linus skills are fairly basic. Thanks so far, I will also try audacious.
I'd recommend, indirectly, arch, but suggest using either Manjaro or Antergos. Either of these make installing and using arch a more palatable experience.
Manjaro Linux – Enjoy the simplicity
Antergos | Your Linux. Always Fresh. Never Frozen.
Thanks Yatsushiro, both good o.s but will take ages for me to digest.I'd recommend, indirectly, arch, but suggest using either Manjaro or Antergos. Either of these make installing and using arch a more palatable experience.
I tried lubuntu with audacious and liked that but it did show up a basic problem that I cant monopolize the tv monitor just to play music, its a shared tv. So I will keep daphile system and the other system for video.It depends on the planned usage of that computer and your linux skills.
Thanks for the help getting here.
Hello
thyristor44
You may still use Daphile. On your media server, you just need to install logitech media server. Thereafter, in your Daphile settings, you just need to set it up for an external logitech media server by inserting the ip address for your logitech media server.
Could I add logitech media server to my existing operating system or is it an operating system itself.You may still use Daphile. On your media server, you just need to install logitech media server. Thereafter, in your Daphile settings, you just need to set it up for an external logitech media server by inserting the ip address for your logitech media server.
Thats a good way out.Or another option are two monitors. I like it for my HTPC - the auxiliary work gets done on a smaller LCD, the movie runs on living room TV.
It is a package that runs on top of an existing OS, like Debian. The main issue will be ensuring that you can source all the pre-reqisites for any particular Distro.
This Debian Package - SqueezeboxWiki should run on any Distro that is based on Debian (Ubuntu, anything that is Ubuntu based.. Rasbian, etc)
- PC Based
- Need an audiophile music player for puppy tahr
