Is anyone using the RPi 3 with the ifi ipower? I'm on my second ipower. The first one would not boot the Pi. This one does however, there is a intermittent flash of the red led while I'm playing music; either streaming (wifi) or usb.
There are no drop-outs and plays consistently. I'm not really impressed, the standard psu sounds just as good.
Maybe I should connect the ipower to the Digi+ and see what happens (just not ready to solder the connections on yet and void the warranty... yet )
I have powered usb hub coming, maybe that will help.
sys= RPi3, 128GB SSD to usb, Moode, Digi+, Bluejeans coax, Emotiva XDA-1 (soon to be replaced)
Any thoughts about this psu?
thanks
eis
thanks
eis
You might search for "DC pigtail" to avoid cutting into the ipower
No, sorry, I didn't mean doing that to the ipower. As soon as you solder the pigtail to the Digi+ board you void its warranty.
eis
Well, given your description, I won't be getting one. It's expensive, quality control is poor, and it provides no apparent benefit.
Thanks for saving me the time/money!
I'm looking into PSU(s) for a rpi 3 + HiFiBerry DAC+ Pro.
As far as there is ever a consensus in Hifi, I have found:
The main PSU (driving the RPI CPU, HDMI, Internet etc) is not very important; the standard wall wart is fine. A better PSU does not give better sound.
There is clear benefit to be had (on the DAC+) by driving the Analog stage with a (very) clean external PSU
https://support.hifiberry.com/hc/en-us/articles/205732441-DAC-Pro-external-power-supply
However, since the onboard regulator (ADP150) is spec'd at only 9uV noise, the external PSU does need to be "very good" for the desired improvement to happen.
It is possible to inject power after the ADP150 (via fancy track cutting and soldering), but this is definitely above my pay grade.
BugBear
BugBear
Not really about power supply?
BugBear
Thank you - that looks like a nicely finished LT1083 based PSU.
I found this:
...datasheet for the LT1083. The RMS noise is specified as 0.003% Vout, ... for the 5V it's 0.15mV.
BugBear
To make up for any possible jitter...
iFi S/PDIF iPurifier: entry-level pricing, next-level results | DAR__KO
If your Pi stack includes a reclocker then maybe you don't need it.
Given the already 9uV noise of the DAC+ built in regulator, I'm looking for external PSUs that can do even better.
Older high performance regulator boards use complex circuits to either augment (or do without) higher noise regulator IC.
But recent regulator ICs give high performance "out of the box".
In particular, (from DIYINHK) we have
4.17 uV noise 4.17uV Ultralow noise DAC power supply regulator 3.3V/5V 1Ax2 - DIYINHK TPS7A4700 based kit (2 channel) 50 USD
1.0uV noise http://www.diyinhk.com/shop/audio-k...dac-power-supply-regulator-33v-50v-800ma.html ADM7150 based, 40 USD
.8 uV noise0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A*x2 - DIYINHK LT3042 based kit, 60 USD.
On this forum, MRAVICA has offered a TPS7A4700 based kit at 24€, but he has none for sale at the moment.
On eBay at the moment, my googling led me to item 252501322400, a single channel TPS7A4700 kit from "alexey.ivanov" in United Arab Emirates (?!), at 30 USD.
The same guy also offers a tiny TPS7A4700 based board that is a plug in replacement for a 317 regulator in pre-existing boards.
Does anyone know this alexey.ivanov, or his designs? At the moment he's the cheapest available for TPS7A4700.
BugBear (off to look for LT3042 boards)
- PC Based
- RPi 3 ifi ipower
