PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 1st February 2018, 04:27 PM   #13171
jv275475 is offline jv275475
Originally Posted by Man in a van View Post
Did you perform this task?
I don't know if it is pertinent to your problem or not
Just guessing
ronnie
That step can be done once LocalUI starts and I see the browser. But seconds after localUI starts, I get that error, and the whole system becomes unresponsive. The only thing I have managed to do is to connect through ssh and disable localui. Then the system works ok (without touchscreen, that is).
In another SD card I have MoOde Beta 11, working ok with Touchscreen. If I put in that card, everything works ok.
I may to build for a third time, but first I'd like to know this is even possible.
Can somebody confirm they have MoOde 4.0 working with an official Touchscreen?
Old 1st February 2018, 04:33 PM   #13172
Serverbaboon is offline Serverbaboon  United Kingdom
Originally Posted by TheOldPresbyope View Post
Gentle persons:
Several of us have posted in past years about following good computer security practices at home and with moOde.
Almost everything you enter in moOde is stored in clear text. This includes your WiFi credentials and your TIDAL, Google Play Music, and QOBUZ credentials. I suspect this is true for many rival players as well.
Now that I have tested that Google Play Music works in moOde 4.0 I think I'm going to delete my account from it. Why? While the other music services stand alone, your Google Play Music credentials are your Google account credentials. If someone were to grab them and you haven't enabled two-factor authentication in Google, then they could impersonate you on Gmail, buy items on your account in the Google Play Store, and otherwise do material harm.
Obviously, two-factor authentication is becoming a necessity on the Google end, yet a recent report says fewer than 1 in 10 Gmail users have enabled it. On the home front, a strong firewall on your network, use of good non-default login passwords everywhere, and other good security practices should be employed but I'd bet the 1-in-10 number applies here too.
Just my gloomy 2-cents worth.
Kent
As a couple of extras.
For Qobuz you can enter the MD5 hash of your password, this does not work on the website only the API.
For Google you should enable 2fa and then assign an application password to your mood player. There is a link upmpdcli website I will try and dig up.
I think this is why the upmpdcli programmer tried to change the owner and permissions on the config file to the upmpdcli user. However that seemed to cause issues.
Old 1st February 2018, 04:34 PM   #13173
kit1cat is offline kit1cat  United Kingdom
Thanks for info Tim and Kent, this is the second build I have tried. I had the same wifi problem in the first build. Perhaps it will be third time lucky :-)
Old 1st February 2018, 04:35 PM   #13174
Of course these are not total mitigations and Kent's recommendations about your firewall and changing your Moode PW are advisable.
Old 1st February 2018, 04:57 PM   #13175
Hi Tim,
I ran the mpc enable only 1 command on my first build, can you see any other errors in my system info file, thanks.
S Y S T E M P A R A M E T E R S
Date and time = 2018-02-01 17:56:52
System uptime = up 5 minutes
Timezone = Europe/London
moOde = Release 4.0 2018-01-26
Host name = moode
ETH0 IP = unassigned
ETH0 MAC = b8:27:eb:0f:c8:0f
WLAN0 IP = 192.168.1.215
WLAN0 MAC = b8:27:eb:5a:9d:5a
HDWR REV = Pi-3B 1GB v1.2
SoC = BCM2835
CORES = 4
ARCH = armv7l
KERNEL = 4.9.78-v7+
KTIMER FREQ = 100 Hz
USB BOOT = enabled
Warranty = OK
ROOT size = 2.9G
ROOT used = 76%
ROOT avail = 693M
FS expand = not expanded
MEM free = 713 MB
MEM used = 54 MB
Temperature = 41.9C
CPU GOV = performance
MPD SCHDPOL = TS
P3-WIFI = On
P3-BT = Off
HDMI = Off
ETH0 CHECK = Off
MAX USB CUR = Off
UAC2 FIX = Off
SSH server = Off
LED0 = on
LED1 = on
C O R E S E R V E R S
PHP-FPM = 7.0.27
NGINX = 1.10.3
SQLite = 3.16.2
Bluetooth = 5.43
C P U L O A D
CPU %usr %sys %idle
all 0.00 1.15 98.85
0 0.00 0.00 100.00
1 0.00 0.00 100.00
2 0.00 4.81 95.19
3 0.00 0.00 100.00
P R O C E S S L O A D
PRI RTPRIO COMMAND %MEM PSR %CPU
19 - kworker/2:2 0.0 2 8.4
19 - sysinfo.sh 0.2 3 2.0
19 - systemd 0.6 1 0.6
19 - sudo 0.3 1 0.5
19 - systemd-journal 0.4 1 0.2
19 - systemd-udevd 0.3 3 0.2
19 - worker.php 1.1 1 0.2
29 - mpd 2.0 0 0.1
19 - kthreadd 0.0 2 0.0
C L O C K F R E Q U E N C I E S
arm = 1200 MHz pwm = 0 MHz
core = 400 MHz emmc = 249 MHz
h264 = 300 MHz pixel = 0 MHz
isp = 300 MHz vec = 0 MHz
v3d = 300 MHz hdmi = 0 MHz
uart = 47 MHz dpi = 0 MHz
SD card = 0.195217 MHz
S Y S T E M V O L T A G E S
core = 1.3250V
sdram controller = 1.2000V
sdram I/O = 1.2000V
sdram chip = 1.2250V
U I C U S T O M I Z A T I O N S
Theme = Standard
Accent color = Emerald
Alpha blend = 1.0
Adaptive background = No
Background image = No
Playback history = No
Extra metadata = Yes
Library = Use Artist
A U D I O P A R A M E T E R S
Audio device = Allo Boss DAC
Interface = I2S
Hdwr volume = 84
Mixer name = Digital
Output stream = Closed
ALSA version = 1.1.3-5+rpi3
SoX version = 0.1.2-2
Volume knob = 52
Volume mute = Off
Volume limit = 80
Bluetooth controller = Off
Airplay receiver = On
Squeezelite = Off
UPnP renderer = Off
DLNA server = Off
Rotary encoder = Off
Encoder params = 100 2 3 4 5
Crossfeed = Off
Parametric EQ = Off
Graphic EQ = Off
Auto-shuffle = Off
Autoplay = Off
MPD crossfade = Off
M P D S E T T I N G S
Version = 0.20.12
Volume control = hardware
ALSA device = hw:0
SoX resampling = disabled
SoX quality = very high
SoX multithreading = off
Audio buffer (kb) = 4096
Buffer before play = 10%
Output buffer size (kb) = 81920
Volume normalization = no
DSD over PCM (DoP) = no
Replay gain = off
A I R P L A Y S E T T I N G S
Version = 3.1.7
Friendly name = Moode Airplay
Metadata display = Off
ALSA device = hw:0
Volume mixer = auto
Resume MPD after = No
Output bit depth = S16
Output sample rate = 44100
Session interruption = no
Session timeout (ms) = 120
Audio buffer (secs) = 0.0
S Q U E E Z E L I T E S E T T I N G S
Version = 1.8.7-1020 "DSD/SRC enabled"
ALSA device = hw:0
ALSA params = 80:4::1
Output buffers = 40000:100000
Task priority = 45
Codec list = flac,pcm,mp3,ogg,aac,alac,dsd
Other options = -W -D 500 -R E
M O O D E L O G
20180201 174919 worker: - Start
20180201 174919 worker: Successfully daemonized
20180201 174919 worker: - Init
20180201 174919 worker: Session loaded
20180201 174919 worker: Debug logging (off)
20180201 174920 worker: Host (moode)
20180201 174920 worker: Hdwr (Pi-3B 1GB v1.2)
20180201 174920 worker: Arch (armv7l)
20180201 174920 worker: Kver (4.9.78-v7+)
20180201 174920 worker: Ktyp (Standard)
20180201 174920 worker: Gov (performance)
20180201 174921 worker: Rel (Moode 4.0 2018-01-26)
20180201 174921 worker: Upd (None)
20180201 174921 worker: MPD (0.20.12)
20180201 174921 worker: USB boot enabled
20180201 174921 worker: File system not expanded yet
20180201 174921 worker: HDMI port off
20180201 174921 worker: File check ok
20180201 174921 worker: - Network
20180201 174921 command/moode: Connection to MPD failed
20180201 174921 worker: eth0 exists
20180201 174921 worker: eth0 address not assigned
20180201 174921 worker: wlan0 exists
20180201 174921 worker: wlan0 trying SSID (Belkinb17a7c)
20180201 174921 worker: wlan0 (192.168.1.215)
20180201 174921 worker: - Audio
20180201 174922 worker: ALSA outputs unmuted
20180201 174922 worker: Audio out (I2S audio device)
20180201 174922 worker: Audio dev (Allo Boss DAC)
20180201 174922 worker: ALSA mixer name (Digital)
20180201 174922 worker: MPD volume control (hardware)
20180201 174922 worker: Hdwr volume controller exists
20180201 174922 worker: Chip options (Burr Brown PCM5122)
20180201 174922 worker: - Services
20180201 174924 worker: MPD started
20180201 174924 worker: MPD scheduler policy (time-share)
20180201 174924 worker: MPD output 1 ALSA default (on)
20180201 174924 worker: MPD output 2 ALSA crossfeed (off)
20180201 174924 worker: MPD output 3 ALSA parametric eq (off)
20180201 174924 worker: MPD output 4 ALSA graphic eq (off)
20180201 174924 worker: MPD crossfade (off)
20180201 174924 worker: Airplay receiver started
20180201 174924 worker: Airplay volume mgt (auto)
20180201 174924 worker: - Last
20180201 174924 worker: USB sources (Ext Drive)
20180201 174924 worker: NAS sources (mountall initiated)
20180201 174924 worker: Volume level (52) restored
20180201 174924 worker: Maintenance interval (21600)
20180201 174924 worker: Watchdog started
20180201 174924 worker: Ready
Old 1st February 2018, 05:25 PM   #13176
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by Iltuocapo View Post
Hello Eric thanks for answering.
I'm in the office and I will try again tonight but I suspect I'm on a different issue.
Let me explain better.
As I mentioned in my post I originally tried the "manual" way.
Started by flashing a Stretch image, then followed the various steps taking them from the 2.3 procedure script.
Going through the list, I issued the various "sudo reboot" commands after each "STEP", and all went well. I mean, after the reboot the system regularly came up again, I could ssh into it, it stayed stable and I could go on issuing more configuration commands until the subsequent reboot.
All OK. Until step 9.
After rebooting after step 8, in facts, the system does come up, I can ssh into it, but shortly after I start issuing STEP 9 commands it goes down (SSH connection is lost).
Green light on the Pi stays solid green, but the system won't apparently actually reboot, letting me regain control and continue the procedure.
I did not "wait for long", tbh.
Again, I'll try again tonight and I'll let you know.
Ciao
Alberto
Is there a reason you are issuing commands manually and not running it as a script, as it was intended?
Old 1st February 2018, 05:30 PM   #13177
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi @kit1cat,
The mpc command should not have to be run manually if the build was clean. Both the manual Build Recipe and the automated Image Builder include that command at the end of the step below.
STEP 9 - Alsaequal
Maybe try looking at /home/pi/mosbuild.log for any errors...
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 1st February 2018, 05:30 PM   #13178
TheOldPresbyope is offline TheOldPresbyope  United States
@Serverbaboon
Thanks for that. I had not twigged on the notion of a Google "application password".
Kent
Old 1st February 2018, 05:58 PM   #13179
sakytu is offline sakytu  Slovakia
Originally Posted by TimCurtis View Post
Can you describe some real-world scenarios where moOde users will be affected by your claim below?
"SMB 1 is risky due to ransomware WanaCry vulnerability. So that would be better to look for another player"
If you can provide evidence that this is a real concern than I can investigate some options in Samba.
-Tim
Hope nobody was and will be affected in the future. My father in law has a company PC unfortunately without updated windows and this malware encrypted all standard files (docs, pictures, pdfs etc.) no way to bring it back so I am scary.
Thanks to my IT colleague and 3 days of research we found a way how to share WIN10 files without spacieal setup. Just need to create/use account with password, than share files (add mentioned account permission) and the most important thing to do is wuallaaaa use Mount flags like this: vers=2.0 no need to use SMB 1.0 in windoze
Enjoy!
Old 1st February 2018, 05:58 PM   #13180
TomWoB is offline TomWoB  Switzerland
Quick question for the 4.0 builder (sorry not clear):
Does it install the Image on sd-card of builder (same card) or on a second one, connected with an USB adapter like the beta12 did ?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2019 diyAudio
