PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 24th May 2020, 09:57 AM   #3891
DRONE7 is offline DRONE7  New Zealand
Then maybe this would be a kludge...?
Old 31st May 2020, 02:05 AM   #3892
bront is offline bront
Default UTC time default/etc/rcS file missing
The setting to use local time for the system was in the file default/etc/rcS but after the May 2020 update that file does not exist. Is there some extension to settings that needs to be installed to add the rcS file?
Old 31st May 2020, 09:19 PM   #3893
hifix is offline hifix  Australia
hifix's Avatar
I have just tried to install daphile (real time kernel) on 2 pcs with different outcomes.
1. On an intel nuc 8 i3.
"Image Authorization Fail.
System cannot boot to this device due to security violation."
And the system goes no further.
2. On an intel atom n550 eee PC
The USB device is not even recognised. It goes straight to windows no matter the boot priority.
If anyone can chime in with a heads up it would be much appreciated. I had my heart set on running this with the eee pc as it has a screen and is far more compact than the nuc (with screen and keyboard).
Thanks and regards
hifix.
Old 1st June 2020, 03:37 AM   #3894
Daphile is designed to be run as a headless device so apart from initial install the screen and keyboard will be of little use.
(There is a local user option where they would work but from experience this is not a pleasant way to run Daphile...the local UI is...very basic and hard to navigate and you can't make settings changes from it so still need to run headless for settings and admin)
Not sure about your USB stick... if it were me I would check if the boot flag was set.
You should be able, with the USB stick inserted to the eeePC, to start and go directly to bios and select the stick as the boot option.
Old 1st June 2020, 02:42 PM   #3895
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Question Best DSD settings
What are the best settings to upsample files to DSD256?
Power:
CPU Frequency: Dynamic or maximum or other?
CPU Security: nothing or disable all optional CPU exploit mitigations?
Clock Source: TSC or HPET or ACPI_PM?
Hyper-threading: nothing or disable?
Audio Devices:
Advanced:
Resampling filters:
Quality: very high or high?
Phase response: minimum phase or intermediate phase or linear phase?
Bandwith: steep filter or nothing?
Audio Devices:
Advanced:
Conversion to DSD:
Noise shaping: sdm-4 or sdm-5 or sdm-6 or sdm-7 or sdm-8 or clans-4 or clans-5 or clans-6 or clans-7 or clans-8?
DSD to DSD cut-off: 30kHz-200KHz, I have 50kHz it's ok?
Attenuation: -6 to -12dB,I have -7dB it's ok?
Audio Devices:
Advanced:
Track transition delays:
Sample rate change: 0-3000ms, I have 1200ms it's ok?
PCM-DSD mode switch: 0-3000ms, I have 1200ms it's ok?
Native DSD mode quirck: nothing or fix DSD64 - PCM 88.2kHz transitions?
Audio Devices:
Advanced:
Player buffering:
Stream buffer: 256-2048Mb, I have 3200Kb it's ok?
Output buffer: 4096Kb, I have 4096Kb it's ok?
Audio Devices:
Advanced:
Kernel/ALSA buffering:
Buffer time: 1-400ms, I have 100ms it's ok?
Period count: 2-40, I have 3 it's ok?
If it's something I forget please share
TIA
Felipe
Old 2nd June 2020, 07:18 PM   #3896
hifix's Avatar
Hey thanks DRONE7
I have got it going.
Using Rufus to get a working image on to the USB seemed to do it. I was using etcher prior.
Old 3rd June 2020, 07:05 PM   #3897
kaiserkeks is offline kaiserkeks
Unhappy Wireless: No compatible devices
Hello all,
after successfully testing daphile with an old (super noisy) laptop I bought a Mini-PC specifically to use it as a streamer with dapihle.
The problem now is, that I cannot set up a wifi connection, because "No compatible devices" are found.
Under Win10 I can set up a wifi connection without any problems.
The PC is a TrekStor W1 (Mini-PC not the Surfbook with the same name) with a Quad-Core Intel Atom Z3735F and a Realtek RTL8723BS wireless LAN adapter.
Do you have any suggestions what I can do?
Thank you so much for your help.
Old 4th June 2020, 12:28 AM   #3898
@kaiserkeks.
Daphile supports many but not all wifi hardware.
One workaround is to use a usb wifi adapter known to work with Daphile.
There are several posts in this thread about such including,
Alternatively you may wish to contact the Daphile developer and request help....see the contact at the bottom of this page..
Daphile – Digital Music Convenience for Audiophiles
bob
Old 4th June 2020, 06:01 AM   #3899
@Drone7:
Thanks for your reply.
If nothing else works, I will use the workaround with the usb wifi adapter.
However, thereīs one thing thatīs a bit suspicious.
Although the pc has a headphone jack, daphile did not find an audio device either, before I connected the DAC via USB.
Could there be a setting that prevents daphile from finding any devices?
Old 5th June 2020, 02:53 PM   #3900
fillingham is offline fillingham
I have a question that is not specific to Daphile - forgive me if it is unwelcome. I have been using Daphile almost from the beginning, very happily. I use squeezer to control it, but like as far as I know all the remote apps, the navigation within a track is just a linear slider limited by the screen size. This is fine for a four minute song, but if the "song" is a four hour opera, it is hopeless to skip back or forwards a minute or so or even ten minutes or so. Is there any app or any other way of controlling it that behaves more like e.g. the BBC iPlayer/Sounds interface, allowing much more controlled navigation?
Thanks.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
