PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 2nd April 2019, 02:09 AM   #3411
Tromperie is offline Tromperie  Australia
Banned
I am hoping he will see this post and look into it.
I suggest sending Kimmo a message on the Dahile website. He rarely visits here because of the strange notions of some people.
Old 2nd April 2019, 04:42 AM   #3412
olcher is offline olcher  Russian Federation
Thanks for the reference. I will surely try.
Old 2nd April 2019, 06:22 AM   #3413
leoncino is offline leoncino
I had an RME AD-2 DAC for a few days.
But I noticed that the mixer button is no longer present on the device.
What is the lack of the mixer button? Can the lack of the mixer button cause damage?
Old 2nd April 2019, 08:19 PM   #3414
Mr Trev is offline Mr Trev
My search-fu failed me…
Is there any way to prevent Daphile from putting changed music files into the "new music" menu?
I'm constantly revising tags/artwork in Musicbee, trying to get my library "just so". I have Musicbee set to "not" change the time stamp whenever I make changes, but those files/albums always end up in the new music menu in Daphile (I recently discovered out why my embedded artwork order wasn't showing properly and now I have ~50 albums that are "new" but have actually been in my library for years)
Also, does anybody know if Daphile supports SMB3? A recent question about connection issues got me wondering. Out of the box Daphile is set for SMB2, which is known to cause issue with Win.10 (probably why I needed to reactivate SMB1 to get my Win10 laptop to see my Daphile machine again). In theory if it could be switched to SMB3 the problem should go away.
Old 3rd April 2019, 08:34 AM   #3415
Triplefun is offline Triplefun  New Zealand
Originally Posted by dhayes5 View Post
Thank you for the suggestion. I checked FunctionDiscoveryResource and Samba is enabled. Both Client and Automatic Removal checkboxes are checked.
It is not only Windows that will not connect, the NAS which is Unix based, also won't connect.
I really think it is something changed in the software. This happened once before. Again the break came with daphile-18.12-b300725-x86_64-rt. When I reload daphile-18.07-b090752-x86_64-rt everything goes back to working.
Since this is the only thing that changed - seems like the problem is with the software.
Again, this happened before and Kimmo was able to fix it in a beta version that he sent to me (or rather a download link) and subsequent releases. I am hoping he will see this post and look into it.
For now I will just stick with the version that works.
If this is an issue with daphile then a lot more people would be complaining. I've had similar issues which gradually resolved themselves over time. I put it down to poor Network settings, firewall issues and router cofiguration issues.
I listen, therefore I am !
Old 10th April 2019, 11:07 AM   #3416
Default EVGA Nu Audio PCIe card
Originally Posted by seanwu View Post
I am thinking build a PC with EVGA Nu Audio sound card. I was wondering whether Daphile support or will support it?
Good news. On your suggestion and based on the interesting reviews I took the plunge and bought the EVGA NU Audio PCIe card. While I will be using it in Windows I decided to give it a go using Daphile from a USB. You will be pleased to know it is indeed recognized and I was able to resample the music, including Tidal, to DoP 128 with an excellent sound. Hopefully Daphile will one day support native DSD256 which is within the capabilities of this card.
Old 10th April 2019, 11:58 AM   #3417
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I listen native DSD 256 using Daphile & Amanero.
Old 10th April 2019, 11:59 AM   #3418
Is that with the EVGA Nu Audio card ? Note I loaded the native BETA using the USB drive. I could see Native DSD256 but it would not let me select it.
Old 10th April 2019, 05:11 PM   #3419
No I don't use any audio card.
Old 10th April 2019, 06:11 PM   #3420
PjVervoorn is offline PjVervoorn
If the samba version changed, you might need to set the protocol and enable ntlm.
In /etc/samba/smb.conf, in the [global] section...
server min protocol = SMB2
ntlm auth = yes
Edit: do not set "protocol = SMB2" as this sets the MAX protocol version.
W10 requires SMB3, setting max lower breaks W10 connectivity.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
