Please - SEARCH!!!!
Don't you read Threads in PASS about transistors.
Even Pass himself had commented on this IRFP244.
I have also invested effort and research into 2 posts
in this thread:
How good is IRFP244 compared to IRFP240
halo - sometimes does not understand his diyaudio.com-friends 😕
Dear jeclkjeclk said:HI touti
what will prefer you to them IRFP 240 OR IRFP 244 😎
in this thread:
Use SAME thread for SAME subject
jeclk
You have already started athread about IRFP240.
I guess you are new here, but if we do like you did
it would not be so easy to discuss subjects.
If same Subject is in 5-10 different THREADS .. 😀
I guess you understand 🙂
You should have posted here, in this thread you started before:
Irfp 240 !!!!!!!!!!
/halojoy - will try to answer 😎(after some research with www.google.com )😎
Last 3 months 11 posts mention IRFP244, here at diyaudio:
IRFP244 - searchresult
Last 3 months 4 posts mention IRFP 244, here at diyaudio:
IRFP 244 - searchresult
Transistors should
always be Written: IRF530 or IRFP252 not: IRF 530 or IRFP 252
Now I had to make two "search" to get
IRFP244 and
IRFP 244
it is a hard work to use "SEARCH" here at diyaudio,
but it is something ALL should LEARN to do!
thinks
/halo
jeclk
Irfp 240 !!!!!!!!!!
Transistors should
IRFP244 and
IRFP 244
thinks
/halo
