A42 in Threshold amp
In some Threshold amp, I found configuration like this for A42. Base and collector are tied together, but the emitors are more positive than the base/collector.
What is the name of using this transistor like this? How many mA will pass in this configuration?
No doubt I believe you, you sometimes do have that tendency 😉 which we all like I presume.
Only from a commercial point of view, two transistors are more expensive than a zener. Well, for mass consumer products that would be the consideration.
/Hugo
In Threshold/Statis design I found many not usual things, but as I experimented it usually results in good sounding.
One aspect is the degeneration RE. In books or commercial schematics, seldom use bigger than 0.22ohm. In your design (majority) it never less than 0.68ohm, more likely 1ohm.
Mr. Pass,
Some designs don't use RE for bipolar EF output stage. I tried this and tried 1ohm RE for single EF pair (not parrareled), they do exhibit different sound characteristic. I first tought big RE is not good, since it will introduce more xover switching distortion. But from experiment, big RE does the opposite way, the sound is more relaxed to hear. The handbooks suggest opposite direction 😀
In the terms of sound quality (not talking about current sharing in parrareled output stage), what is the importance of RE or big valued RE? What is your personal opinion on EF complementary output stage that don't use RE (just connecting Emitor-Emitor-output line)?
