maartentje said:Hai Guys,
I have draw a new pcb for the bride of zen, the earthing is much better and the 2 channels are symmetric.
Greetz Maarten
Dear Mr. Maarten,
Thank you for uploading the upgraded pcb drawing.
I have a question for you but also for anyone reading this.
I really don't understand this necessity of symmetry for the two channels.
On principle I prefer an identical pattern for the two channel.
But often I have seen the two channel mirrored.
Why I don't know.
Kind regards,
beppe61
I think it's only a layout problem. I found it's much easier to route it, if the components for both channels are mirrored..
for my PCB, i positioned the components to achieve a 'ground track' surrounding the other tracks in the PCB, and i've mirrored both channels each other. routing the PCB was a job of minutes...
the result is shown here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=49611&perpage=10&pagenumber=1
tell me your opinion!
DarkStar
DarkStar
darkstar666 said:I think it's only a layout problem. I found it's much easier to route it, if the components for both channels are mirrored..
DarkStar
Dear DarkStar,
Thank you very much indeed for your kind and extremely valuable reply.
Regarding your project I would like to congratulate you: very nice job indeed !
As I am particularly interested in line preamps, I would be very interested in knowing how your Bride of ZEN sounds.
In general I am looking for a minimalist line preamp (if you want to search for author beppe61 you will find the schematic of a 2 BJT line preamp that I found) to substitute a Bryston .4b I am using now.
Any your further information on line preamps would be very much valuable to me.
I look forward to hearing from you.
Kind regards,
beppe61
hallo, thanks for the reply! regarding other minimalist preamp project... the only one i've seen are these:
-a TUBE single ended preamp (http://www.tnt-audio.com/clinica/ta/simpre0.html)
-the Hiraga MC (http://www.bonavolta.ch/hobby/en/audio/prepre.htm)
-another TUBE preamp and a passive one (http://www.users.globalnet.co.uk/~valveamp/LinePreProject.htm)
[source of most of these links: www.epanorama.net]
hope this helps!
DarkStar
hope this helps!
DarkStar
darkstar666 said:hallo, thanks for the reply! regarding other minimalist preamp project... the only one i've seen are these:
hope this helps!
DarkStar
Dear Darkstar,
Thank you very much indeed for your valuable suggestions.
Just another question: did you build your modified BOZ?
What is your opinion on its sound ?
It is a good alternative to commercial line preamps?
Kind regards,
beppe61
- New PCB for bride of zen
