hello,
i have order at diy store all what i could buy there to building the f6. i look at the guide 6l6 but for me isn't 100% what i should need for parts between toroid and power supply.
one guy from netherland wrote.
You need rectifiers between toroid and power supply, also simple protection circuit.
okay, but what is it excatly and where can i see it in the guide from 6L6?
Other problem is, my english isn't good enough to understand all
Thanks for our help.
F6 PSU details are in post #1 of the build guide by 6L6.
Link is here: diyAudio Power Supply Circuit Board v3 illustrated build guide - diyAudio
hello,
use Google Translate to read pages
hello,
okay, but what is it exactly and where can i see it in the guide from 6L6?
Other problem is, my English isn't good enough to understand all
Steppen , it's not your English the problem , you need to have a minimum understanding of electricity to build an amplifier , you first have to learn about , otherwise you will struggle a LOT each and every steps
New inquiry: Does the F6 need a 300VA or 400VA transformer (or other?) Antek makes both. I have purchased two 200VA toroids to make monoblocks assuming they are a good size. But what does an F6 need for a stereo amp? Any comments on proper size for mono or stereo versions? How much current does an F6 channel consume?
300VA 2x 110V
- F6 Power
