Aleph 5 - How to demonstrate it is "Single ended"
Thread Tools
Old 3rd December 2020, 07:13 PM   #21
codyt is offline codyt  United States
codyt's Avatar
At least there’s a Santa Claus
Soekris 1321 | Grace F9E > Pearl II > B1v1/B1v2/H2v2/BA3-FE/WBA18/ACP+ > F4/F6/AJ/ZMJ2/AJSS > TAB10-SIGs
Old 4th December 2020, 03:13 AM   #22
6L6 is offline 6L6  United States
6L6's Avatar
Please look at the following links. (Greatly simplified, but very good illustrations for this conversation)
The first is a single-ended output stage, similar to the output of the Aleph amplifiers.
Source Follower
The device has to either turn more off or more on to modulate both the positive and the negative part of the signal.
This is a push-pull output stage.
Simple Push-Pull Follower, with Distortion
One device for the positive part of the wave, another device for the negative part of the wave.
Old 4th December 2020, 04:28 AM   #23
elwood625 is offline elwood625  United States
elwood625's Avatar
What a great way to illustrate how the A/C and D/C components in a circuit coexist.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, Aleph J, H2, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter, FS NJFET RIAA
Old 4th December 2020, 09:06 AM   #24
Pierpulp is offline Pierpulp  Italy
Excellent support 6L6!!
Thanks to everybody!
This is a real smart and friendly community.
And thanks to Mr. Pass and his humility to participate to the discussion. Great man as well as scientist and artist!
Old 4th December 2020, 01:00 PM   #25
N101N is offline N101N
Devices in push-pull configuration act as each other’s current sources, if you prefer to look at it that way. The considerably higher efficiency (thereby higher distortion) of push-pull topologies, which is the prime reason to use them, remains unexplained.
  Reply to this post
Aleph 5 - How to demonstrate it is "Single ended"Hide this!Advertise here!
Thread Tools
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 21 9th August 2018 05:04 PM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 07:55 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 09:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
