Best choice for Aleph 30 re-cap
Joined 2007
A friend brought his original Pass Labs Aleph 3 to me to check out a couple of weeks ago, and when I peeked under the hood I could see some of the power supply filter caps had crowned tops. The little 220uf caps all tested high for ESR, so I changed all the electrolytics out for the original factory values. Now that friend has brought me his Aleph 30. The caps in this amp don't show physical deformities, but since it's a 17 year old Class A amp and easy to work on, I'm going to replace them.
The Aleph 30 is an improvement over the 3, so I'm curious about the difference in total capacitance in the power supply:
  • Aleph 3 stock caps: Panasonic UP 25v 22,000uf x 8 = 176,000uf
  • Aleph 30 stock caps: Panasonic UP 50v 10,000uf x 12 = 120,000uf
Is the reduction in total capacitance relevant or was the value in original Aleph 3 simply overkill?
I've gone through various replacement options offered by Digikey, and have narrowed my choice down to the following:
  1. CDE 380LX 50v 10,000uf x 12 = 120,000uf
  2. Nichicon LLS 35v 15,000uf x 12 = 180,000uf
There are no 105c rated caps that will fit in this application. I understand the 50v rating is higher than needed, so would the additional capacitance offered by the 35v Nichicon caps a point in their favour? I know they are both well respected brands. Or am I overthinking a trivial detail?
I'll use Nichicon KA for the 220uf values.
Thanks in advance.
I agree with pico on the Nichicon's for the PSU. 35V rated is all that is needed with a +/-24VDC supply and the extra capacitance will be good.
The KA's are a good cap, or you could look at Nelson Pass's favourite being the Elna Silmic II for the 220uF.
