Forte Model 1 and Forte Model 3 Adjust Bias
Old 30th May 2020, 09:18 PM   #1
EddieRock is offline EddieRock  United States
Default Forte Model 1 and Forte Model 3 Adjust Bias
I've read a few posts here about adjusting the Bias and I'm a bit confused on which resistors are the emitter resistors. I've attached a pic of the board. Can someone point out which is the emitter resistors and which posts I should get the meter readings from when adjusting?
See attached image. Ultimately, an arrow to the component would be helpful
Also, there is talk about replacing the pot for a 20 turn and this board has one I believe. Can someone send me a link to the correct POT to purchase? I've got a Forte Model 3 and a Forte Model 1 that I'm getting up and running.
thanks for all you do!
MacBook Pro | Cambridge Audio DAC | Adcom GFP-565 | Forte Model 1 & 3 | Klipsch Forte II | Klipsch Heresy II | M&K MX125 | Bluejean
Old 30th May 2020, 09:44 PM   #2
llwhtt is offline llwhtt  United States
The right leg of the big transistors are the emitters and connected to each emitter is a big gray resistor, that's the emitter resistor. Put one DMM lead on one end and the other lead on the other end. Use mini-grabbers or clips if you have them. The left leg is the base and the middle leg is the collector.
Craig
Old 31st May 2020, 05:30 PM   #3
So, what your's saying is measure where the two arrows point in the pic below?
Also, do I have to measure the reading on all or is just one good enough?
Thanks!
Old 31st May 2020, 06:37 PM   #4
Chamberman is offline Chamberman  United States
Yes measure where the two arrows are pointing.
Just measure across the one resistor. The other resistors are assumed to be the same.
KC
Old 8th June 2020, 06:15 PM   #5
This was very helpful. The Forte Model 1 is running now around 48 degrees Celsius. Sounds FANTASTIC!
Please note, the emitter resistors varied in millamps around 68mV to 75mV when at 48 Celsius. Is that a concern that there is a wide range?
If so, what should I be looking at to see if there is another component I should determine if it is failing. Or is that just the +/- of the component tolerances?
thanks!
Old 8th June 2020, 09:41 PM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
No, that's fine. 10% tolerance is pretty good.
Old 8th June 2020, 10:33 PM   #7
Thank you Mr. Pass!
I absolutely love these amplifiers (own a Forte Model 3 and Model 1).
I'm so happy that you actually replied! Bucket list (not really but awesome)
back to you!!
  Reply to this post
Forte Model 1 and Forte Model 3 Adjust BiasHide this!Advertise here!
Forte Model 3 Bias Zero Cool Solid State 16 13th May 2018 04:52 PM
forte model 3 bias pot help joshuahhhhhhh Solid State 2 11th October 2015 07:19 AM
Converting Forte Model 3 to Model 1a LouieTheG Pass Labs 2 7th May 2015 04:42 PM
Forte model 3 4krow Pass Labs 21 7th May 2015 04:02 AM
Forte Model 1 hum tonywood Solid State 2 20th May 2014 08:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
