ALEPH 5 Oscilating 600KHz
ALEPH 5 Oscilating 600KHz Please consider donating to help us continue to serve you.
Old 24th March 2020, 08:07 PM   #21
wayne is offline wayne  United States
Auburn
wayne's Avatar
It would not hurt at all to try 680 Ohm gate resistors on the outputs.
wizards assistant
Old 26th March 2020, 08:18 AM   #22
Extreme_Boky is offline Extreme_Boky
The output MOSFET could be slightly damaged to cause that behaviour. I remember having the exact same symptoms, a long time ago, on few occasions, when I worked for Jands electronics (PA amplifier of some 2KW per channel, bipolar and/or MOSFET's). I also recall that you played a lot with one pair, two pairs... of output MOSFETs, so you did a fair bit of touching-the-legs activity.
If the oscillations go down with 680ohm gate resistors, then replace all MOSFET's and try again. If the oscillations disappear, go back to the original value of gate resistors.
Old 26th March 2020, 08:49 PM   #23
Alex79 is offline Alex79
Hello all,
with original values of 221R gate resistor and 680pF capacitor amplifier goes into oscillation. It is nicely visible on square wave, where is heavy overshooting and ringing.
Increasing gate resistor to 680R reduces overshooting as well as ringing, but it is still there and causing oscillation. If I increase 680pF capacitor, I have nice square wave. Due to increase in gate resistor, I probably do not need to increase the value of capacitor too much. Im still looking for right value, maybe 1nF would be enough. Waiting for ordered components to test.
And yes, the mosfets are not best quality. They are heavily used IRFP244 get from some old device, as obtain NOS 244 is almost mission impossible. I can change it for 240 but first I wanted to hear the original design
So seems, this is the way to fix my oscillation. Thank you all for help, really appreciate.
Old 26th March 2020, 09:31 PM   #24
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
after second look at your pcbs ...... LTP mosfets are on one end of long pcb , while LTP CCS mosfet is on other end of pcb
pcb made like that, with that logic - no wonder that bloody thing is oscillating
buy better pcbs
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th March 2020, 01:20 PM   #25
vitalica is offline vitalica  Europe
vitalica's Avatar
I agree with Zen Mod. When I tested BJX, in which on the long PCB, there are 10 pairs of MOSFET, I only mounted one pair for tests. For a long time I searched for the reason for the oscillation in the speaker. I got rid of the problem only after mounting all the MOSFET.
Old 27th March 2020, 01:33 PM   #26
Zen Mod's Avatar
different reason, most probably ..... edit: certainly
servo circuit optimized for greater number of outputs , so with just one pair in situ , servo having excessive gain for tiny xconductance of just one pair ; when all outputs are in place, servo gain and OS gain are in equilibrium
easy to conclude after, when you did that test
ALEPH 5 Oscilating 600KHzHide this!Advertise here!
shelf oscilating psu east electronics Power Supplies 9 22nd November 2012 12:57 AM
How to create self oscilating SMPS luka Power Supplies 10 7th January 2007 06:41 PM
Aleph P oscilating or something else!!! bbakota2000 Pass Labs 4 30th August 2004 04:17 PM
Looking for self oscilating class D lumanauw Class D 14 2nd March 2004 03:14 PM
oscilating in capacitive load borisov57 Solid State 3 24th January 2003 12:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
