ALEPH 5 Oscilating 600KHz
Old 22nd March 2020, 01:43 PM   #11
Alex79 is offline Alex79
Originally Posted by Extreme_Boky View Post
Yes, exactly right. However, you will also change the AC gain by playing with a 1-ohm resistor. Nelson has explained how to empirically set the AC gain, so you can set the quiescent current properly, for symmetrical clipping, AND set the AC gain at 50% which seems like a desired amount of gain.
So I end up to have 1 Ohm resistor (0.5A current) together with 2.2K resistor instead of 1K. I was not going mainly for symetrical clipping, but measure for best THD regrding almost max power output. With 2.2K I get best THD and also clipping symetry get much better even it is still somehow assymetric. So thank you for help with biasing.
So main issue stay to be 600KHz oscilation when connected to speakers. Still trying to eperiment with it, however without success yet
Old 22nd March 2020, 04:41 PM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Several suggestions:
With lab supply, consider some capacitance from rails to ground
Doesn't oscillate without a source? what if you short the input to ground?
Oscillates with load? How about with about .1 uF + 5 ohms to ground?
Old 22nd March 2020, 05:54 PM   #13
Hello Nelson, thank you for great design.
It is strange, never see such behaviour with amp before. But first time building Mosfet amp. It doesnt oscillate if I use just dummy 8ohm load.
When I attach speakers, it starts oscillating 300-600KHz 10-20V pk-pk. It is oscillating even when no source or inputs shorted to ground. If no load or full load, the value doesnt change.
I tried to see what happening on rails. POSITIVE to GND nothing. GND to NEGATIVE - 4Vpk-pk 300-600KHz noise.
If I try different lab supply, same behaviour.
Something strange going on negative rail.
Old 22nd March 2020, 05:57 PM   #14
rayma is offline rayma  United States
Try using the same speaker wires, but with the dummy load.
Old 22nd March 2020, 08:22 PM   #15
So after more experimenting, What really make difference is the 680pF capacitor. I have to increase it to 4nF or more and now oscillation is gone!
Thank you all for help.
Old 22nd March 2020, 08:49 PM   #16
The one and only
That capacitance figure is still higher than you want.
What about dummy load and RC network at output?
Old 23rd March 2020, 11:36 PM   #17
Mark Tillotson is offline Mark Tillotson
My immediate thoughts looking at the circuit diagram are where's the rail decoupling
and the Zobel network?
Old 24th March 2020, 03:59 PM   #18
The one and only
The production Alephs did not require either, but DIY versions will often
have different parts, layout, and/or errors. This case may be one of those,
and the decoupling and zobel won't hurt, and might help indicate where
the problem is.
Old 24th March 2020, 04:33 PM   #19
I note this is a likely known issue since the Aleph 3: Aleph 3 oscillations
I'd never recommend avoiding rail decoupling, its first and strongest defence against unwanted positive feedback paths. I note the Aleph P uses decoupling on at least one rail.
Skimping on this because it happens to work in a particular configuration is, erm, questionable, to say the least.
Old 24th March 2020, 05:21 PM   #20
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
originals were never oscillating
DIY iterations - sometimes ...... it all depends of physical layout and execution
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
ALEPH 5 Oscilating 600KHzHide this!Advertise here!
shelf oscilating psu east electronics Power Supplies 9 22nd November 2012 12:57 AM
How to create self oscilating SMPS luka Power Supplies 10 7th January 2007 06:41 PM
Aleph P oscilating or something else!!! bbakota2000 Pass Labs 4 30th August 2004 04:17 PM
Looking for self oscilating class D lumanauw Class D 14 2nd March 2004 03:14 PM
oscilating in capacitive load borisov57 Solid State 3 24th January 2003 12:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
