Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#21 |
The one and only
I received samples of the Jfets from a customer who also used the DCA
Pro semiconductor tester and complained that they were not meeting match spec of 1 mA. Tested here, all 4 of the LSK170 / LSJ74 pairs were well within the 1 mA match, and formed two matched quad sets also well within the spec. It turns out that this is a limitation of the DCA Pro. (It's right in the manual - I have one). The voltage source is 12V at open circuit, but drops with Idss current so that it's about 5 volts at 6 mA and with these 7 to 10 mA parts, goes even lower, well out of the saturation region (Idss is saturated current). While the DCA pro is a nice little tool, you don't use it to match higher current Jfets, or any other high current / high voltage tests. ![]() |
#22 | |
#23 |
#24 |
That is not the reason.
#25 |
The one and only
Interesting point.
First, the LS parts are not literally identical to the Toshibas. I ran matching comparisons N and P channel parts from LS versus the Toshiba parts I got slightly different results. The parts were 8.0 mA Idss at 12V, and two samples each of the four types were examined for Idss for Vds from 3 to 12 volts. For the Toshibas the Idss wanders about 0.5 mA over that voltage range, and the match between the two wanders about 0.2 mA. The LS parts wander between 0.5 to 2 mA Idss from 3 to 12V Vds and the matching changes by slightly more than 1 mA. The voltage of the test clearly influences the matching, and we see that for more money you can get better matching with the Toshibas. For what we are doing here, the LS parts work fine. If you want the Toshibas anyway, Punkydawgs is a reliable source. ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New Use for DIYAudio Store Heatsinks | jmotzi | The diyAudio Store | 1 | 18th October 2018 09:08 PM |
Not able to open diyaudio store | wtl | Forum Problems | 5 | 7th July 2015 12:21 AM |
Can't open The diyAudio Store | merlin el mago | Forum Problems | 5 | 20th November 2014 07:02 AM |
Help on diyAudio Store Chassis | eskwadrat | Construction Tips | 3 | 14th June 2014 03:21 PM |
Welcome to the diyAudio Store Support Forum | Jason | The diyAudio Store | 0 | 20th December 2012 07:42 AM |
New To Site? | Need Help? |
