Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#11 |
Hoopy Frood
Hi uchu007, for Idss, you probably want to test with Vds=10V and Vgs=0.
Your tester seems to be quoting Idss values at varying and quite low Vds voltages.
We are fearless amplifier builders. A little heat doesn't scare us at all. - NP 2002 |
#12 |
Yet the idss of the peers that I had from Punkydawgs are well 7.35 for the 2sk170 and 7.38 for the 2sj74 and those of the store that I just received are much lower below 6ma
#13 |
Official Court Jester
as I said - test them at higher voltage
besides that , that guy above ( better known as My Papa), claiming 1mA as OK , is a guy who made that amp ![]()
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#14 |
Hoopy Frood
For the B grade, the Idss should be between 6 and 12 mA, and
is based on current value with Vgs=0 and Vds=10. When I look at the 2sk170 Vgs=0 blue curve near the top of the graph in your first post and extrapolate to Vds=10, it looks possible the curve will make it over 6mA.
#15 |
I still think that I will use the pair that I got on ebay in Punkydawgs and that those from the store will stay in their box!Because I’m pretty thorough and it’s really going to bother me to have such a gap. I still have the memory that in the French magazine Jean Hiraga explained that it was necessary a very demanding pairing of transistors and that it was important
#16 |
different amps , different criteria
#17 |
Ok Zen mod in any case I thank you all and especially Nelson for these sharing! I enclose a small photo of the assembly of the cards in progress
#18 |
Hoopy Frood
As Papa has said, this is the entertainment business, so use the parts you
want to give you maximum enjoyment and not keep you up at night. ![]() Have fun with your build! Dennis
#19 |
diyAudio Administrator
Hi Uchu! The store is only interested in your total satisfaction.
You have now heard what is required for your project. As Dennis said you should absolutely use the parts that give you maximum enjoyment and let you sleep well at night. However in this case it does look like some more testing needs to be done. Mistakes can happen and if these are actually outside of the standard we'll of course make things right. Please get in touch at contact@diyaudiostore.com so we can take care of you. |
#20 | |
I already contacted you by email. I mounted the pair I had on the bay because the ones in the awning are not close enough for me. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New Use for DIYAudio Store Heatsinks | jmotzi | The diyAudio Store | 1 | 18th October 2018 09:08 PM |
Not able to open diyaudio store | wtl | Forum Problems | 5 | 7th July 2015 12:21 AM |
Can't open The diyAudio Store | merlin el mago | Forum Problems | 5 | 20th November 2014 07:02 AM |
Help on diyAudio Store Chassis | eskwadrat | Construction Tips | 3 | 14th June 2014 03:21 PM |
Welcome to the diyAudio Store Support Forum | Jason | The diyAudio Store | 0 | 20th December 2012 07:42 AM |
New To Site? | Need Help? |
