Buffer with Dual N-Ch Jfets and Dual Power Supply
Thread Tools
Old 7th April 2019, 11:17 PM   #51
vdi_nenna is online now vdi_nenna  United States
vdi_nenna's Avatar
106.6mV across 18 ohm source resistor on current source jfet and same across buffer jfet source resistor.
I figure that's just under 6mA.
I build, therefore I am.
Do not create problems where there are none.
Old 7th April 2019, 11:59 PM   #52
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
use 8R2-10R as lower , use 20R trimpot as upper
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th April 2019, 01:28 AM   #53
vdi_nenna's Avatar
Thanks ZM. The target is 10mA?
Old 8th April 2019, 11:17 AM   #54
Zen Mod's Avatar
target is , say , 90% of Idss
Old 8th April 2019, 11:41 AM   #55
vdi_nenna's Avatar
Ok, to avoid saturation.
Old 8th April 2019, 01:50 PM   #56
vdi_nenna's Avatar
One more question. I'm not trying to state the obvious here, but not sure of the impact of needing matched quads.
For example, I have a well matched pair of sk170s at 9.76mA for channel 1 and another set at 10.50 and 10.52mA for channel 2.
Will there be, let's call it, a "balance" issue between channels?
I want to assume- Yes they should be quad matched, because they are technically biased at different currents,
but if that's what they require to be at 90% of their Idss, then does it matter if both channels have quad matched JFETs?
Thanks,
Vince
Old 8th April 2019, 02:41 PM   #57
Zen Mod's Avatar
everything ok , at least in my book
that's just buffer , not critical as some other implementations
Old 8th April 2019, 06:57 PM   #58
EUVL is offline EUVL  Europe
Yes, because the transconductance (and hence Zout) at 9.7mA is slightly lower than 10.5mA.
So the DC will be low for both, but they are not 100% identical.
Patrick
xen-audio.com
Old 8th April 2019, 07:32 PM   #59
vdi_nenna's Avatar
All very interesting. Now that I understand the parameters a little better, I can play around with the different jfets I have available.
Thanks for everyone's help!
Vince
Old 22nd April 2019, 05:35 PM   #60
vdi_nenna's Avatar
What do you think about some resistance on the input?
Mr Pass uses 1k in some buffers.
Right now using a 1M to ground.
Is it needed or help prevent issues?
Using schematic 15c on first page.
Buffer with Dual N-Ch Jfets and Dual Power SupplyHide this!Advertise here!
Thread Tools
Dual jfets kinku Parts 5 20th April 2017 05:21 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 04:17 PM
FS: Dual Jfets in metal can. Tarasque Swap Meet 2 26th July 2015 11:26 PM
Dual supply B1 Buffer andreaemme Pass Labs 0 5th January 2014 10:58 AM
Dual JFETS on EBAY Andypairo Swap Meet 7 11th December 2003 12:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
