Buffer with Dual N-Ch Jfets and Dual Power Supply
Thread Tools
Old 15th March 2019, 07:27 PM   #21
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Can I get an extra set of eyes on this?
Are the two B-grade BF861 Jfets listed exactly the same?
bf861 NXP RF JFET Transistors | Mouser
thanks.
I build, therefore I am.
Do not create problems where there are none.
Old 15th March 2019, 07:46 PM   #22
rco3 is offline rco3  United States
The ,215 parts come on a reel of 3,000. The ,235 parts come on a reel of 10,000. If you are producing large numbers of final product, you may find that ordering a reel of 10K gives you different statistics for part-to-part variation than three or four reels of 3,000. If you are buying a couple of dozen for your personal projects, I suspect the difference is irrelevant.
Old 15th March 2019, 07:50 PM   #23
vdi_nenna's Avatar
Going for the cheaper part.
Old 21st March 2019, 01:14 PM   #24
vdi_nenna's Avatar
I wimped out and only picked up 25 qty BF861 and 25 qty J113. Also 50 SOT-23 to SIP adapters. Still have a bunch of 2SK170 ranging from 3mA to over 20mA Idss.
Soekris DAC's output is off the R2R array and said to be 1.2V. Can a buffer be made with 15v rails that will produce at least that much output from the buffer?
B1 does it with +19v, so I'm guessing +/-15v rails can achieve at least 1.2v output.
Old 29th March 2019, 06:06 PM   #25
vdi_nenna's Avatar
Default Question about matching
When matching jfet Idss, when is the reading taken?
Is it the first mA reading one sees or after a certain amount of time or certain temp the jfet reaches?
I noticed the mA reading changes over time.
Old 29th March 2019, 06:10 PM   #26
EUVL is offline EUVL  Europe
Steady state, as in operation.
Patrick
xen-audio.com
Old 29th March 2019, 06:19 PM   #27
vdi_nenna's Avatar
Thanks Patrick. So if running them at 15v, leave the test run at 15v for good amount of time.
Old 29th March 2019, 06:22 PM   #28
Correct.
And if you use a heatsink (for thermal coupling), then it is best to test it as such.
But we are getting towards perfection now .....
Patrick
xen-audio.com
Old 29th March 2019, 06:31 PM   #29
vdi_nenna's Avatar
Happy to have finally gotten this question resolved.
Thanks!
Old 31st March 2019, 02:47 AM   #30
vdi_nenna's Avatar
I tested ten J113 jfets so far and lowest Idss so far is 17.17mA at 15v.
Can source resistance help?
Buffer with Dual N-Ch Jfets and Dual Power SupplyHide this!Advertise here!
Thread Tools
Dual jfets kinku Parts 5 20th April 2017 04:21 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
FS: Dual Jfets in metal can. Tarasque Swap Meet 2 26th July 2015 10:26 PM
Dual supply B1 Buffer andreaemme Pass Labs 0 5th January 2014 09:58 AM
Dual JFETS on EBAY Andypairo Swap Meet 7 11th December 2003 11:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
