Hi, I got a B5 active xover from my friend.
I wan to set up my system like this:
DHT pre amp --> B5--> DIY F4 Clone --> OB speakers
My DHT #26 pre amp have gain about 8x, enough vol swing for f4 but I'm not sure about clipping point of B5.
In B4's user mannual, B4's clipping >10v but I didn't find out anything the same in B5's user mannual.
Is that B5 got wide bandwith and low THD at 8-10V output???
Thanks.
Thanks.
that's question for Pa
however , guessing rails at 24V (sum ...... being either +/-12Vdc or once 24Vdc ...... one can expect decent* performance in voltage envelope few volts lower than rail(s)
so , shave few volts from 24 and that's your Vpp
*that's tricky part ...... but remember that pretty much same sort of buffer is in F4 , even if having higher rails ..... principle is the same
just go and try it ; you'll hear clipping if there is any ...... and nothing can go poof!
