I’m very interested in making my own preamp, or repair an old high end amp.
There is an abundance of fm transmitter and receiver components. I recognize some of the pieces as being high end audio components. I just can’t identify all of them. I was hoping some of you can identify them and let me know if I have a good basis and if this is possible. Thank you all for you’re replies.
The Mallory polystyrene and Electrocube capacitors are worth salvaging, but use a heat sink
on the leads when unsoldering.
Hi 06meaeri,
If you're going to design and build your own preamp, the used components will be fine. If you set your sights on restoring a piece of equipment, better to buy new parts so that you can select ones that fit properly. Besides, many parts have been improved after those ones you have were made. Especially resistors and electrolytic capacitors.
-Chris
-Chris
