So I'm looking at a mogami db25 cable to replace my stock ambilical cable on my pass xp20, really for no other reason than I'm trying to clean up my cables and the stocker is longer than needed. I read in an earlier thread that pass uses all the pins and from what I can see the mogami db25 has a pin out that leaves one pin blank as in the picture attached
Will this pin out work? Or is the 25th pin required. Thanks
Many of the connections are paralleled I can check if that one is used Tuesday. We also have some short cables in stock just call and we can send one.
Sorry to resurrect this...did you have a chance to check? Ran into the same situation and saw this thread through Google search.
