Threshold Stasis 3 Amplifier Capacitor Replacement
Hi hope can get an answer to these questions😋🤔🤔
I have a Threshold Stasis 3 with low temperature operation
I want to replace the Trim Pots as they are faulty
I will have to open the amp and do some stripping of parts and boards
Should I replace any of the caps while I have the unit open ?
I see some tantalum caps and some electrolytic ones too
According to the schematic it has the following caps per channel
1 of 4.7uf 25v
2 of 47uf 50v Radial type
1 of 470uf 6.3v Axial type
2 of 0.15uf 50v
1 of 0.1uf 400v
2 of 39pf
1 of 390pf
2 of 680pf
Which to replace ?
Thanking you in advance for the replies🤗🤗🤗
A bit of confusion, clarity sought
Hi
Set about the task but found this point that does not make sense.
I see what I think is a capacitor here with the following written on it
PSll .001 +|-2% 100vdc
I would presume this is a capacitor of 0.001uf 100vdc with 2%tolerence
This value of capacitor however does not show on the circuit diagram
Am I wrong in this in some way
Please help 😕😕😕
Thank you
Umesh
I have read that the original 47uf 50v Infstrument Devices caps are marked on the positive side and not the negative. Capacitors are usually marked on the negative.
So is it true then that these in the Threshold Stasis 3 are marked on the positive side ?
I have read this on this forum some time ago
Your help is appreciated 😉😉😉
Thank you for clearing up the info. Would have definitely messed it up without this vital info. Would have just gone on convention.
who cares for stripes
just decipher how to put them - from schematic
That would be the best way but just to be sure had to ask
I have one Threshold Stasis 3 with a blown channel due to ignorance so just being cautious
I don't believe that I have to consult the great oracle again.
Capacitors arrived today. ( sent a friend to buy them in major city close by )
They are the correct value but much longer.
Question of the day 😕😕😕
Can I install away from the circuit board, sort of floating in one of the following configurations ?
Does this have any resonance or other detrimental implications ?
Please advise
Hi
Did the cap swap out and switched on and a resistor blew. On the power transistor section T03 type .😱😱😱
Probably a transistor or two not sure. A question arises.
Does the axial cap in the picture also have an arrow pointing to the positive side as well ? As I presumed the axial cap would be conventionally noted
Anyway I will probably resort to professional services after this as I have had no luck with this amp. I now have two blown amps.
Should have probably asked this before switching on.
Hind sight 20/20
Please advise on this situation.
Thank you
I replaced the trim pots as well.
When replacing the trim pots does one place the resistance between the two active legs on a high or low valve to protect the circuit down the line ?
The answer is probably obvious and scary coming from someone who is actually dabbling with electrical work
