IRLB3813 Triode-curve
Old 10th April 2020, 11:45 AM   #41
Circlomanen is offline Circlomanen  Sweden
I have not tested or played with any new interesting mosfets for a while now.
I would recommend the IRFPS3810 as the most "normal" and useful of those mentioned above. The IRFP7430 might be lots of rock&roll and fun, but it is something of an acquired taste. It can sound really good in a sourcefollower setup, and it would probably be really good for the lower part in a cascode.
They are quite cheap and is still available so I would recommed everyone to stock up on them today. The world is slowly but surely moving away from large high power devices like these.
The IRL3103PBF, IRFPS3810 and IRL3803VPBF has already got an NRND rating on mouser, so I am happy I stocked up on them last year.
They all have nice useful curves and maximum safe operating area, and once people find out how nice and well sounding they can be in simple amplifiers then the last of them will dissaper fast.
We live in a horizontal world, why use vertical topologies???
Old 10th April 2020, 01:25 PM   #42
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
I picked up a few IRLP3034s and trying to put together a choke loaded SE amp with a Hammond v193 inductor. Using a 6.7A SMPS.
I build, therefore I am.
Do not create problems where there are none.
Old 10th April 2020, 05:49 PM   #43
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Many of the curves we have seen here show performance at high currents not
representative of intended use. Also, I am suspicious of any curves that have
kinks in them.
My recommendation is always to buy two of anything and see what you get.
Old 10th April 2020, 08:49 PM   #44
vdi_nenna's Avatar
Thanks Mr Pass. Be fun to see what comes out of it anyway.
Will this schematic work? The inductor is 1 ohm, 3A.
Old 10th April 2020, 10:11 PM   #45
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
it'll work, why not
concept older than transistor
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th April 2020, 10:26 PM   #46
vdi_nenna's Avatar
Haha! That's a good one!
As a starting point, was going to measure 2v drop across the inductor for 2A.
Is that the correct way to go about it or should I be looking for a voltage midway between the 24v voltage source?
Is the voltage mid point used when there's an active CCS?
Thanks!
Old 10th April 2020, 11:31 PM   #47
TungstenAudio is offline TungstenAudio  United States
Yes, that would be a good way of setting the quiescent current, given the 193V has a DC resistance of 1 Ohm. Start with a 2V drop across the choke.
There is another very simple circuit from tube days of yore. Have you looked at the MoFo?
Old 10th April 2020, 11:41 PM   #48
Zen Mod's Avatar
decide what Iq you want to have , then measure voltage across source resistor to get it
you'll have drain voltage as rail minus voltage drop across choke , so practically 24Vdc-(Rchoke*Iq)
"voltage midway" you can get only if you have more ohms between rail and drain , be it pure resistor group or "active" resistor - anything done with big mosfet or BJT (Mu, CCS, Gyrator)
Old 11th April 2020, 12:39 AM   #49
vdi_nenna's Avatar
Oh, yeah. Love it.
...anything done with big mosfet or BJT (Mu, CCS, Gyrator)
Was also thinking about experimenting by inserting some resistance between the inductor and mosfet and also playing with the source resistor.
IRLB3813 Triode-curveHide this!Advertise here!
Anyone has a curve tracer to trace Western Electric 436A 448A 418A in triode mode ? HP8903B Tubes / Valves 18 13th May 2016 03:12 PM
12T10 triode connection - similar "real" triode to compare to? geezertron Tubes / Valves 16 28th February 2015 10:23 PM
Looking for TT11(CV1501) triode mode curve olaychang Tubes / Valves 0 18th January 2010 09:29 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
