IRLB3813 Triode-curve
Old 30th March 2015, 04:32 PM   #11
WalterW is offline WalterW  Netherlands
what a strange MOSFET....transconductance: min. 140 Siemens
continuous drain current 260 ampere for a TO-220....
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2, Pass XS Pre amp.
Old 30th March 2015, 05:11 PM   #12
thiagomogi is offline thiagomogi  Brazil
This curve is the triode ?????
Old 30th March 2015, 05:26 PM   #13
martinsson is offline martinsson  Sweden
It is a bit strange isn’t it, but I like strange and testing something a bit different, I believe the triode characteristics is likely to become more apparent when you lower the Amperes (look at the vertical scale) and extrapolate the trend it exhibits around 8-10V.
Old 30th March 2015, 05:28 PM   #14
would be better?
http://www.irf.com/product-info/data...a/irfs3207.pdf
Old 30th March 2015, 07:28 PM   #15
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Would you get better bass response by doubling in size the input and output caps, like in the Zen amp series?
Is it 1.6A across the drain resistor? Is it 40-50w?
I build, therefore I am.
Do not create problems where there are none.
Old 30th March 2015, 08:27 PM   #16
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
Yes, triode on lsd
Svakog dana u svakom pogledu sve manje nazadujem.
Old 30th March 2015, 08:34 PM   #17
good point
Old 30th March 2015, 08:35 PM   #18
hesener is offline hesener  Germany
nice amp to build using a couple of those leftover notebook power supplies
Paradise documents are here: Link list
Old 31st March 2015, 04:09 AM   #19
This is the state of the CAD "virtual build" at the moment, it is by no means not finished just quite yet, but it is a good exercise in routing and component packaging, all components below are dimensioned according to their respective specs.
The PS is 200VA 9+9V and the PS Cap's are 6x 15.000uF.
Old 31st March 2015, 05:45 AM   #20
With respect for the fact that this is niether the topic of the thread or a Pass amp (although it is heavily inspired by Mr. Pass work according to the designer Circlomanen) I think it would be more apropriate to perhaps start another thread about this build in a more apropriate forum section, it was only ment as an example of what I'm plannig to do with this perticular transistor.
IRLB3813 Triode-curveHide this!Advertise here!
Anyone has a curve tracer to trace Western Electric 436A 448A 418A in triode mode ? HP8903B Tubes / Valves 18 13th May 2016 03:12 PM
12T10 triode connection - similar "real" triode to compare to? geezertron Tubes / Valves 16 28th February 2015 10:23 PM
Looking for TT11(CV1501) triode mode curve olaychang Tubes / Valves 0 18th January 2010 09:29 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
