Aleph 30 - noise in right channel
Hi All
My trusty Aleph 30 has over the last week developed a strange habit - it would start to put out an audible crackling White noise on one of the channels after some hours of use - and it now does it on turn on - all the time. There seems to be some DC offset as the woofer moves outwards a bit and stays out.
The amp plays music "fine" - even on the noisy channel, however the noise is always present, and independent of volume - it's also present without signal input cable plugged in.
Any ideas/suggestions on where to start?
Only non-stock change is that the LTP input transistors and CCS are changed to Zetex ZVP3310 fets.
Best regards
Hans
Pictures, thought audio files would be more helpfull 🙂
Anywhere, here goes:
BTW - where/what's OPLDF?? 🙂
Best regards
Hans
Hmmm Zen Mod - I recall a document made by you, something about how to convert the sissy Aleph30 into a less sissy Aleph J? Think it might be good excuse now I have to change the Little Black input fuses after all...?
However, the search gives no result...
Best regards
Hans
