Aleph J and F4 dissipate roughly 105.6W at stock settings. The F5 disspates roughly 88W,
moi thinks that Pa deliberately keeps us confused , all these years
If he is considering the store board for the aleph j , then he has four get per channel biased at 1.2A each and running 22V rails. Bout 200w per stereo amp, correct? F4 has 3 pairs at about .4A each and 22V rails, making about 100w for stereo. F5 has single pair biased at 1A, I think, not sure, and 22 v rails makes 88W. I am sure I missed something. Thinountain air getting to my brain.
assuming 2x22Vdc is resulting PSU voltage from 2 x 18Vac Donut , and all values are taken from Papa's FW pdf's :
F4 : 200mV across 0R47 means : (0V2/0R47) x 44Vdc x 3 =56,17W dissipation/channel
F5 : 0V59 across 0R47 means : (0V59/0R47) x 44Vdc x 1 = 55,23W dissipation/channel
J , nothing else but :
misleading , all the time ............ in other words : ook ya , use your head , nothing is carved in stone
edit : conclusion - one need different eggs , to posh them on different FW amps
Place the amplifier in a well-ventilated location, as it draws 200 watts
during operation and requires as much opportunity to cool itself as
possible.
- Pass F4, F5 and Aleph J - which runs coolest?
