Hi guys. Second time DIYer. My first project was making passive woofers and that was easy Af, but this time id like to recycle a dead (motherboard) polk audio omni S6 speaker an repurpose it for pleasure.
What I am trying to accomplish is preserve and reuse the chassis and PSU from this system. Since the motherboard has both the dac/crossovers (accepts positive and negative of both tweeters and woofers (4 cones)) I purchased external crossovers to keep the lines simple. In regards to the power supply it seems to push 32 volts through a 4 pin molex labelled 32v/32v/gnd/gnd and is accepted by the motherboard at 22volts (as labelled next to the pins)
I'm planning to gut the motherboard and replace it with a Dayton Audio KAB-250 but want to know if I am on the right path and exactly how I would connect the PSU to the 24v dayton (4 pin molex to 2 pin). Am i onto something here or am I reaching for the stars with this project. See images below.
I am by no means an electrician and have the education of a 3rd grader when it comes to dealing with circuitry... maybe less. Please go easy on me lol
Guts of the POLK S6
Dayton AMP
Dayton Schematics
Guts of the POLK S6
Dayton AMP
Dayton Schematics
