Are there any traditional conventions or classic values for tube amp/pre building?
!/2 W: 1k, 10k, 47k, 100k, 220k, 470k, 1M
You'll still need other values on occasion.
Experimenting: Get a 1,000-pack of all 5% 1/2W values in carbon-film.
100Values 1000pcs 1-10M ohm 1/2W Carbon Film Resistor Assortment Kit: Amazon.co.uk
1460 Pieces Resistor Kit 73 Values 1%, 1/4 W Metal Film Resistors : Amazon.co.uk
When you need a 680 or a 150k, it will be in there.
(Yes, the 2nd pick is 1/4W. That's fine grid and cathode. Plate resistors can run hot (use Ohms Law) so you may need to series/parallel say 47k and 56k to get 100k 1/2W. Remember these are penny-parts, use as many as you need.)
*Then* when you have a basically happy amplifier, spend for your koa spr2/5 exotics.
- Design & Build
- Parts
- Stocking some resistors for tube apm experiments? Standard convention with values?
