Maybe someone can explain why the huge price increase in the multi-layer cap price of the KEMET 300 Goldmax C0G capacitors?
Yes they were pricy before for the .1uf 100V at $1.90 each. Then about 1/2 that if you bought 1000s of them. Now the 1% are $6.40 and only $3.63 ea. per 1000 5% are $4.59 and only $2.38 ea. per 1000...what is up with that? They aren't even on the Tariff list either.
Try a lower voltage rating, if you can use it. I'm using these, much cheaper.
FG16C0G1H104JNT06 TDK Corporation | Capacitors | DigiKey
Thanks Ray, not bad!
If you need better than 5% tolerance, these will normally run pretty close.
I use them for local hf bypass in audio circuits.
