Depends on the circuit. Most likely are either a single linear pot, or a dual log-antilog pot.
Thanks mate,your right on the ball.You are the only person out of two audio sites that knew that? I found this link,if you scroll down to center weighted balance control it explains it beautifully Potentiometers (Beginners' Guide to Pots).
there are specialized Balance Pots made by Alps -and probabely others too.
The specialty beeing the anti-log character just to the middle position and staying constant above (shorted).
That way both channels remain at full volume in the middle position.
Turning the pot-knob attenuates one channel only, while the other stays at full volume.
A dual anti-log pot would attenuate both channels in the middle position and on turning it'd increase one channel while lowering the other.
jauu
Calvin
jauu
Calvin
