PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Subs for kick drum range
Old 14th June 2020, 10:22 PM   #31
conanski is offline conanski  Canada
Adding to what Chris said, the best way to measure a system like this is outdoors away from structures and for that you need to be able to setup the mic at quite a distance from the system and ideally quite a distance from the computer, so a mic that can utilize standard XLR cables is the way to go.
Old 15th June 2020, 11:59 AM   #32
djteknovibe is offline djteknovibe  United Kingdom
There's no way I can do that I live on a council estate in a 2 bedroom second floor flat.
Old 15th June 2020, 12:12 PM   #33
turk 182 is offline turk 182  Canada
have you tried reversing the polarity of your subs?
try flipping just one and listen for a difference, if possible pan between the two for comparison.
Old 15th June 2020, 01:27 PM   #34
chris661 is offline chris661  United Kingdom
chris661's Avatar
Presumably storing the PA system off-site, then.
In that case, you'll need to measure + align your rig as part of soundcheck. Best to practice on something else first...
Chris
Bits of information and other things I've worked on: https://www.grimshawaudio.com/lab
Old 15th June 2020, 02:03 PM   #35
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Similar issues, I've made lots of measurements during set up and by taking individual bits to relatives houses who have gardens or in friends yards. Even lower quality measurements are better than non. Once you get above 500Hz you can do measurements indoors using time gating. I'm building a battery powered amp setup at the moment partly to improve measurement quality.
Old 15th June 2020, 03:21 PM   #36
My subs are stored downstairs in a store room and my mid/highs are upstairs in my flat. But yeah i'll have to see when I do my events again and measure there.
  Reply to this post
Subs for kick drum rangeHide this!Advertise here!
Kick drum mic (sub kick) nps Subwoofers 6 25th June 2014 10:17 PM
its gotta have more kick drum SS4927 Music 17 3rd June 2014 04:39 PM
Mono Tube Comp for analog kick drum Teamrocket Tubes / Valves 0 26th August 2010 01:04 AM
Kick Drum Microphone DIY? Phonic Red Solid State 2 15th September 2006 06:55 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
